Old 08-13-2019, 11:18 PM   #1
Ol'school
Ol'school's Avatar
Default Y block Mercury engine color?
I have a pair of valve covers from a '56-7 Mercury Y block and want to paint them close to the original colors. Can anyone let me know the color of the valve covers and were the Mercury letters done in another color? Thanks,
Ol'school is offline   Reply With Quote
Old 08-14-2019, 09:10 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Y block Mercury engine color?
Do a search and you can find this info. https://www.fordbarn.com/forum/showt...t=engine+color
And another one:
https://www.fordbarn.com/forum/showt...+engine+colors
Old 08-14-2019, 12:03 PM   #3
KULTULZ
KULTULZ's Avatar
Post Re: Y block Mercury engine color?
Below photos show color sequence 1954-1957.
The 56 MERC Rocker Covers had four different color shemes depending on the HP rating.
File Type: jpg 1956 MERC - Engine Rating By Color ID.jpg (104.0 KB, 69 views)
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
Last edited by KULTULZ; 08-14-2019 at 07:25 PM. Reason: TO HOPEFULLY MAKE THE INFO MORE CONCISE
KULTULZ is offline   Reply With Quote
Old 08-14-2019, 02:46 PM   #4
scicala
scicala's Avatar
The picture with the yellow engine is a '55 Mercury, so this color doesn't apply to '56 or '57.
Sal
scicala is offline   Reply With Quote
Old 08-14-2019, 02:49 PM   #5
scicala
scicala's Avatar
Also the picture of the pale blue or green engine with the oblong air breather is a '54 Mercury 256 Y-Block V8.
Sal
Old 08-14-2019, 05:15 PM   #6
mercman from oz
mercman from oz's Avatar
When you click onto the small photos to enlarge them, the Years of the various models are listed against each photo, but not visible as thumbnail size.
Old 08-14-2019, 06:28 PM   #7
KULTULZ
KULTULZ's Avatar
Question Re: Y block Mercury engine color?
Sal
Uh Sal,
I showed the four model runs of the MERC FYB so colors (engine-rocker covers-ACL) are shown.
- WHY IS IT ... -
Old 08-14-2019, 09:27 PM   #8
Ol'school
Ol'school's Avatar
Thanks for the pictures and good information. I think I know which ones I have now and the proper colors.
Old 08-14-2019, 09:29 PM   #9
scicala
scicala's Avatar
Yes, my stupid mistake. Didn't notice the print on the bottom of the photos. Guess I'm not perfect. I feel good that I knew what they were though.
Sal
Old 08-15-2019, 02:54 AM   #10
KULTULZ
KULTULZ's Avatar
It seems there is much confusion on MERC colors-
Case in point below. GOLD engine, RED intake manifold, WHITE rocker covers and a BLACK BAT WING ACL.
- WHY IS IT ... -
Old 02-21-2020, 07:42 PM   #11
JMFL36
JMFL36's Avatar
KULTULZ, what color green is the darker green on the '54 block? I got the light green from Hirsch, but can't find the darker green anywhere. Thanks, John
Document your car with CollectorCarCompanion
JMFL36 is offline   Reply With Quote
Old 02-22-2020, 02:39 AM   #12
KULTULZ
KULTULZ's Avatar
I wish I could tell you. Usually, color codes (incl engine) are given in the period MPC-CHASSIS CATALOG. I don't see it listed.
Try these guys and see what they have. Please get back as everyone is wanting to know a source.
https://www.eastwood.com/paints/hi-t...ne-paints.html
- WHY IS IT ... -
Old 02-24-2020, 11:19 AM   #13
JMFL36
JMFL36's Avatar
I just got off the phone with the 'experts' at Eastwood. They were of zero help and didn't have a clue where I might find the correct green for the '54 Mercury Y block. Oh well.
Old 02-24-2020, 01:06 PM   #14
KULTULZ
KULTULZ's Avatar
You might try here - http://www.mercuryclub.com/
They don't appear to be as active as in the past.
- WHY IS IT ... -
Old 02-24-2020, 09:33 PM   #15
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
The gold, red, white, batwing(caddy) air cleaner 292 is a motor I built for raceron's '56 Vicky. The gold colored block was a close match to the original color of the '55 Merc block used. The other colors were customer preference and not an attempt at original factory spec.
streetdreams is offline   Reply With Quote
Old 02-25-2020, 06:21 AM   #16
KULTULZ
KULTULZ's Avatar
Red face Re: Y block Mercury engine color?
I apologize for the reference. I was attempting to show that all examples are not OEM.
Please retain me on your CHRISTMAS CARD LIST ...
The 56 MERC engine was painted GOLD wasn't it?
- WHY IS IT ... -
Old 02-25-2020, 11:09 AM   #17
streetdreams
Kultulz, not a problem. Actually, was quite proud to see one of my jobs used as a reference. Not sure, but believe '56 Merc was the same goldish/greenish white as the '55 block/heads.
Old 02-25-2020, 11:17 AM   #18
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Y block Mercury engine color?
I was just using the photo as an example, not criticizing. I mean, it looks nice to me and is the owners desire.
I found this while CAROUSING WITH MY BROWSER looking for the color code -
... searching for 55 merc engine paint, also color of certain parts like the crank pulley and draft tube, was it yellow-tan or black like the fords? this engine has the high compression heads, so according to the service bulletin, the air cleaner and valve covers would be the yellow-tan vs the cream white of the standard compression motor?
I have a MERC TEXT I need to find hidden in a deep dark bunker. Will get back.
- WHY IS IT ... -
Old 02-25-2020, 05:56 PM   #19
scicala
scicala's Avatar
In '55 there were two Mercury Y-Blocks offered. The Montclair came standard with a 198 HP 292 (like the T-Bird), and all other models came with a 188 HP 292. The 198 HP engine was 8.5:1 compression, and the 188 HP was 7.5:1
Based on KULTULZ's quote above, it sounds like 188 HP got the cream/white air cleaner, and 198 HP got the pale yellow one. I know the '55 Montclair I used to have, had the pale yellow one and was 198 HP.
Sal
Old 02-27-2020, 08:13 PM   #20
raceron1120
raceron1120's Avatar
oops, didn't see John's ref to my car above.
raceron1120 is offline   Reply With Quote
