Old 09-10-2018, 11:35 AM   #1
nosoup4u
Default The guy whose car is too fast with a new idea.
I'm the guy who is trying to slow down a model A project because it goes too fast to crawl around car and tractor shows. It has a standard A three speed and rear axle.
Recently ran across a "dual high underdrive". Looks like it would bolt up to the back of the three speed without much problem (or would it?) but would need some fabricating and machining to attach to the drive shaft.
My other question is, does anyone know how much it underdrives? As near as I can find it is 1;1.57. Which I think means if my low speed is now 9 it would be 6 with this added.
nosoup4u is offline   Reply With Quote
Old 09-10-2018, 03:22 PM   #2
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Default Re: The guy whose car is too fast with a new idea.
You better talk to some other A owners to see what is going on with your car. In low gear at a cackle, it is slower than a walking person.
Jacksonlll is offline   Reply With Quote
Old 09-10-2018, 03:49 PM   #3
nosoup4u
I am building a speedster using a combination of Ford A and tractor parts. The tractor engine does not have a real wide range of RPMs. I need the thing to drive slow, like four or five MPH, for tractor shows.
Old 09-10-2018, 03:50 PM   #4
SeaSlugs
SeaSlugs's Avatar
Dual high requires an AA crossmember and special holder/mount for it. Be much easier to install a 4 speed.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 09-10-2018, 03:53 PM   #5
nosoup4u
Will a four speed slip into place where a three speed used to be or will it also take modifcations?
And, so far the cheapest AA four speed I've found is $1800.
Old 09-10-2018, 04:59 PM   #6
Bob C
Here is a link to Vince's site on putting a AA 4-speed in a Model A.
http://www.fordgarage.com/pages/aafourspeedachassis.htm
Bob
Old 09-10-2018, 07:09 PM   #7
redmodelt
redmodelt's Avatar
Truck bell housing, but the U-joint is the big hurdle.
Old 09-10-2018, 08:26 PM   #8
eagle
eagle's Avatar
How did you mate the engine to the trans? Is there a way to run a jackshaft or a gear reducer there? Is it a Dubuque two cylinder?
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 09-10-2018, 08:47 PM   #9
nosoup4u
It is an L engine. The front transmission shaft was adapted to fit the L clutch splines.
Old 09-10-2018, 08:52 PM   #10
eagle
eagle's Avatar
Could you move the engine forward enough to put a gear reduction in there? Are you using the clutch on the engine? That is a Hercules engine. Higher RPM than Dubuque.
Old 09-10-2018, 08:55 PM   #11
SteveB31
SteveB31's Avatar
Install the AA truck 1929-1931 4 speed trans . It has a granny gear, and bolts right in. If you need any of the pieces Bert's Model A Center in Colorado has all the parts you need. It is an easy install. Not pricy
SteveB31 is offline   Reply With Quote
Old 09-10-2018, 09:20 PM   #12
nosoup4u
It’s a later L so it is a Deere engine
Old 09-10-2018, 11:58 PM   #13
40 Deluxe
Doesn't that L engine idle as slow or even slower than an A engine?
Old 09-11-2018, 08:31 AM   #14
nosoup4u
No. And since it is significantly less horsepower than an A engine, you need to keep it wrapped up a bit.
Old 09-11-2018, 09:17 AM   #15
redmodelt
redmodelt's Avatar
https://www.fordbarn.com/forum/showthread.php?t=250962
You could keep it really simple and install a chain drive reduction between the transmission and final drive. Also the size of your rear wheels will change ground speed. How were you planing to install the rear axle?
Old 09-11-2018, 10:32 AM   #16
40 Deluxe
Maybe doing a little math before choosing parts will help. Find out the gear ratios of your current trans and rear axle, tire diameter (or circumference), the RPM your engine needs to run at, and plug these numbers into a formula that will give ground speed. Or, switch the formula around to find the ratios needed to attain desired ground speed. Then look for trannies and/or axles that give that ratio. Maybe both an AA four speed and a "dual high" under drive will get 'er slowed down.
Old 09-11-2018, 10:59 AM   #17
nosoup4u
Yeah, unfortunately that ship has already left the dock. I think if I can find and install a four speed I will be good.
Old 09-11-2018, 11:39 AM   #18
Dodge
Put a second Model A transmission in it. When you put them both in reverse it will go forward so slow you can walk next to it.
Dodge is offline   Reply With Quote
Thread Tools
Display Modes
