Old 10-15-2019, 11:47 AM   #1
History
History's Avatar
Default Radiator Mount?
Are the mounting brackets on the bottom of the radiator of a 1930 sport coupe supposed to go under the fenders or on top? Itís mounted under the fenders now but wrong bolts tells me itís been removed before.
History is offline   Reply With Quote
Old 10-15-2019, 11:59 AM   #2
31Tudor
31Tudor's Avatar
Default Re: Radiator amount?
The tabs go under the fenders.
31Tudor is offline   Reply With Quote
Old 10-15-2019, 12:14 PM   #3
History
History's Avatar
Thank you!!!!!
Old 10-15-2019, 02:38 PM   #4
Bob C
This is what you should have.
Bob
Bob C is online now   Reply With Quote
Old 10-15-2019, 04:14 PM   #5
History
History's Avatar
Bob
Yep thatís what I have now. Someone had used bolts and nuts with square heads and the springs were underneath and tightened all the way down.
Old 11-13-2019, 03:43 PM   #6
Owlseye
Default Re: Radiator Mount?
So the bolts come up thru the frame. Then on top of the frame it gets the rubber pad, then radiator mount flange, then spring, then nut? Can the radiator be spaced slightly higher if needed for alignment and cowl clearance?
Owlseye is offline   Reply With Quote
Old 11-13-2019, 07:55 PM   #7
History
History's Avatar
I'd say it could be raised but from what I've read here (barn) it's the cowl, cab, frame that has gotten lower.
On the rubber pads that go under the radiator, do they go length wise side to side or toward the front to back?
