07-13-2017, 05:26 AM | #1 |
Horn Problem
My horn blows just fine with car running or off. When I turn the lights on or hit the brake it just growls. Do I have a problem with my generator?
07-13-2017, 06:20 AM | #2 |
Re: Horn Problem
No, all sounds normal for a charging system with no voltage regulator. The lights or brake light draws more power than the generator may be set for, and they will then draw a bit of the power from the battery, thus due to line loss, the horn has a bit less voltage available.
If the horn sounds good now, I'd leave it alone, otherwise you could try one click looser on the horn adjustment screw. |
07-13-2017, 06:56 AM | #3 |
Re: Horn Problem
What Tom says, also make sure the horn is lubricated.
Marty |
07-13-2017, 09:46 AM | #4 |
Re: Horn Problem
...And the commutator is nice and clean!
07-13-2017, 10:25 AM | #5 |
Re: Horn Problem
The best "FIX" for horn problems is a 6 Volt, positive ground ALTERNATOR! You'll never be SORRY you did it!
Bill Beep
07-13-2017, 05:02 PM | #6 |
Re: Horn Problem
I have an alternator that is in a generator case. You can't tell it is an alternator. I may put it on and try it. |
07-13-2017, 11:18 PM | #7 | |
Re: Horn Problem
When you blow your horn what does the ammeter read? With the lights on and the horn blowing what does the ammeter read?
07-13-2017, 11:52 PM | #8 |
Re: Horn Problem
It shows discharging the needle goes to the left
07-14-2017, 07:56 AM | #9 |
Re: Horn Problem
How bright are your lights? if the horn blows fine with the car off (lowest possible voltage) id suspect grounding issues and or the headlights/brake lights are somehow grounding thru the horn wiring.
Are your battery terminals clean and tight? Does the car crank over quickly or or is it kinda sick sounding? Somewhere I think you have a corroded/rusted/loose connection as the connection is good enough to power one thing but overload it and it cant get enough juice through.Check your ammeter and junction box wiring as well. are your horn wires under the tabs from the sides?
07-14-2017, 10:57 AM | #10 |
Re: Horn Problem
Install a relay in the horn cover,with direct battery voltage.
07-14-2017, 02:44 PM | #11 |
Re: Horn Problem
Try this. Back off on the adjuster screw until there is no sound. Then hit the button and let horn motor spin up for about 30 sec to a minute. The little motor likes to run. Let it run and it will sound better after you readjust it.
07-14-2017, 03:01 PM | #12 |
Re: Horn Problem
Jackson,
Now that's a new one on me!! My horn's fine, but I might try this just for the heck of it. I guess it couldn't hurt. Marty |
07-14-2017, 04:07 PM | #13 |
Re: Horn Problem
I did let the motor run like you said and oiled it to make sure everything was good and loose. Of course I noticed the horn doing this after I turned on the lights because it was getting dark outside. Otherwise I may not have noticed the problem.
07-14-2017, 04:11 PM | #14 |
Re: Horn Problem
Battery terminals look fine. Ground cable doesn't look really good but I do have a new ground cable I will put on. The headlights are pretty bright. Car cranks over pretty good for a 6volt.
I will have to check other connections. Thanks |
07-14-2017, 05:25 PM | #15 |
Re: Horn Problem
as a test for an iffy ground cable use a stout jumper cable from the ground terminal off the battery to the frame somewhere that is very clean. the temp added ground may do wonders.
07-14-2017, 08:45 PM | #16 |
Re: Horn Problem
Im with Sea Slugs....X 2
07-15-2017, 10:53 AM | #17 |
Re: Horn Problem
You might try moving the horn wire from the generator terminal over to the starter stud.
