12-01-2011, 05:19 PM | #21 |
Re: hole in Cyl. now what
I would ask Ron about this. For the record, I've been running a 59A for several years, with 4-ring pistons, and I am running three rings (leaving off the bottom ring).
(47 passenger, stocker). No problems, and it does not use any oil. What does Ron say?? I realize he has posted something to the effect that his current street engines use 3-ring pistons. Same thing ???? |
12-01-2011, 06:25 PM | #22 |
You can run it either way... My opinion... It's at the bottom of the stroke... I would think about the balance of the motor more than running the forth ring into the hole...
Karl |
12-01-2011, 06:41 PM | #23 |
Well I guess that about covers it then. I will finish putting it together and run it for a couple of minutes on a stand then pull that piston and see how the rings are. If good then I have a couple of fellows who will want it. Thanks again for all the comments and advice. Bill
12-01-2011, 06:57 PM | #24 |
I wouldn't worry about leaving the bottom ring off. Now Does that go into the waterjacket??. Bead blast it and fill it with JB weld.
12-01-2011, 07:01 PM | #25 |
Does not go into water jacket. Seems rather thick.
12-02-2011, 09:30 AM | #26 |
dickspadaro.com |
12-02-2011, 11:47 AM | #27 |
use some sort of spray cleaner-brake, etc and a dremel tool with a brush to clean out do this a couple of times using a light bulb (not the new types) to heat it up which will make the oil run out of the casting and use JB weld and smooth off
Thread Tools | |
Display Modes | |
