Old 01-20-2019, 05:34 PM   #1
mikek6741
Post 1937 humpback sedan 4 door radiator core support
Hi All: I recently acquired a 1937 sedan 4 door humpback, but it is missing the radiator core supports. I have the radiator for it but cannot find anyone with the part to mount this radiator....any help will be appreciated.
Mike K.
mikek6741 is offline   Reply With Quote
Old 01-20-2019, 06:24 PM   #2
1937sedandelivery
Default Re: 1937 humpback sedan 4 door radiator core support
Mike,
I have some 37 stuff, but not sure what you need. Can you identify it based on the picture?
gregg
1937sedandelivery is offline   Reply With Quote
Old 01-21-2019, 10:24 AM   #3
1937sedandelivery
adding picture in view
sorry, screwed it up again...
Old 01-21-2019, 12:07 PM   #4
blucar
blucar's Avatar
Mike K.
The Ford V8's of the 1930's did not have a core support, that is a separate assembly that mounted to the frame, securing the fenders and radiator in place like modern cars.
The '37's had a stamped framework that was attached to the radiator tanks top and bottom with soldier.
The pix I have attached is of a '37 pickup radiator.
Bill.... 36 5 win cpe
Old 01-21-2019, 12:31 PM   #5
mikek6741
The part I need is apparently riveted to he frame horns and bolted to the cross member. Thanks for the pics but I have all of those parts.
Old 01-21-2019, 12:34 PM   #6
mikek6741
Hi Bluecar: You are right; the part I need is riveted to the frame horns and bolted to the crossmember. I need to find someone that has vintage steel in their yard or someone that has street rodded their '37 and no longer needs these "elbows" for aradiator support.
Old 01-21-2019, 03:37 PM   #7
1937sedandelivery
I went through the same thing on my 37. Luckily, I found two very nice pieces. I believe this is what you are needing:
Old 01-21-2019, 03:41 PM   #8
1937sedandelivery
trying to add the picture again.
crap, I think I am following jseery's instructions on how to add a picture to the screen view, but it ain't happenin, oh well.
Old 01-21-2019, 04:14 PM   #9
mikek6741
Thanks....that is EXACTLY what I am looking for; can you remember or tell me where you got them or where I might find some for my car??
Old 01-21-2019, 04:28 PM   #10
1937sedandelivery
one more try adding a picture...
hey, it worked. The secret is that I was trying to add pdf's. When I tried a jpeg it worked, kinda makes sense, now.
I don't remember where I got the brackets, probably on Ebay. I just looked there and can't find any.
Old 01-21-2019, 04:37 PM   #11
mikek6741
Thanks....now, do you have these for sale??? I need left and right side....
Mike K.
Old 01-21-2019, 04:49 PM   #12
mikek6741
OK....thanks. If you do find someone or the brackets in your travels, please give me a heads up or tell the person to contact me.....
Old 01-21-2019, 04:50 PM   #13
1937sedandelivery
Mike,
I don't have these anymore (used them on my SD). BUT, I do have a rusty old 37 frame out back with brackets. If I was a really nice guy, I would grind off the bracket rivets and send them your way.....hmmm, send me a PM.
gregg
Old 01-21-2019, 05:00 PM   #14
JSeery
JSeery's Avatar
The file you are attaching is a pdf file and not a photo file. It attached as a pdf just like it should.
Old 01-21-2019, 05:14 PM   #15
pete rose
I have a pair in very good condition- email me
[email protected]
Let me know where you are located as well
I'm in Vancouver Canada area
Pete
pete rose is offline   Reply With Quote
Old 01-21-2019, 05:56 PM   #16
1937sedandelivery
Thanks Jerry, it finally dawned on me. Let's see if I remember next time, duh....
Old 01-21-2019, 09:31 PM   #17
mikek6741
Thanks. email on its way.
Mike K.
Old 01-21-2019, 09:37 PM   #18
mikek6741
Thanks for the pics. I am new to this form of communication, and don't know what a PM is....clarify please. Pete says he has a pair in nice condition so don't grind off the rivets just yet.
Old 01-21-2019, 09:41 PM   #19
TonyM
TonyM's Avatar
PM is a private message
TonyM is offline   Reply With Quote
Old 01-21-2019, 09:42 PM   #20
TonyM
TonyM's Avatar
PM is a private message. Please click on the name of the member you want to message and then click on the private message feature.
