01-20-2019, 05:34 PM | #1 |
1937 humpback sedan 4 door radiator core support
Hi All: I recently acquired a 1937 sedan 4 door humpback, but it is missing the radiator core supports. I have the radiator for it but cannot find anyone with the part to mount this radiator....any help will be appreciated.
Mike K. |
01-20-2019, 06:24 PM | #2 |
Re: 1937 humpback sedan 4 door radiator core support
Mike,
I have some 37 stuff, but not sure what you need. Can you identify it based on the picture? gregg Last edited by 1937sedandelivery; 01-21-2019 at 10:20 AM. Reason: add picture |
01-21-2019, 10:24 AM | #3 |
adding picture in view
sorry, screwed it up again... |
01-21-2019, 12:07 PM | #4 | |
The Ford V8's of the 1930's did not have a core support, that is a separate assembly that mounted to the frame, securing the fenders and radiator in place like modern cars. The '37's had a stamped framework that was attached to the radiator tanks top and bottom with soldier. The pix I have attached is of a '37 pickup radiator.
Bill.... 36 5 win cpe |
01-21-2019, 12:31 PM | #5 |
The part I need is apparently riveted to he frame horns and bolted to the cross member. Thanks for the pics but I have all of those parts.
01-21-2019, 12:34 PM | #6 |
01-21-2019, 03:37 PM | #7 |
I went through the same thing on my 37. Luckily, I found two very nice pieces. I believe this is what you are needing:
01-21-2019, 03:41 PM | #8 |
trying to add the picture again.
crap, I think I am following jseery's instructions on how to add a picture to the screen view, but it ain't happenin, oh well. |
01-21-2019, 04:14 PM | #9 |
Thanks....that is EXACTLY what I am looking for; can you remember or tell me where you got them or where I might find some for my car??
01-21-2019, 04:28 PM | #10 |
one more try adding a picture...
hey, it worked. The secret is that I was trying to add pdf's. When I tried a jpeg it worked, kinda makes sense, now. I don't remember where I got the brackets, probably on Ebay. I just looked there and can't find any. Last edited by 1937sedandelivery; 01-21-2019 at 04:38 PM. |
01-21-2019, 04:37 PM | #11 |
Thanks....now, do you have these for sale??? I need left and right side....
Mike K. |
01-21-2019, 04:49 PM | #12 |
OK....thanks. If you do find someone or the brackets in your travels, please give me a heads up or tell the person to contact me.....
01-21-2019, 04:50 PM | #13 |
Mike,
I don't have these anymore (used them on my SD). BUT, I do have a rusty old 37 frame out back with brackets. If I was a really nice guy, I would grind off the bracket rivets and send them your way.....hmmm, send me a PM. gregg |
01-21-2019, 05:00 PM | #14 |
The file you are attaching is a pdf file and not a photo file. It attached as a pdf just like it should.
01-21-2019, 05:14 PM | #15 |
I have a pair in very good condition- email me
[email protected] Let me know where you are located as well I'm in Vancouver Canada area Pete |
01-21-2019, 05:56 PM | #16 | |
Thanks Jerry, it finally dawned on me. Let's see if I remember next time, duh.... |
01-21-2019, 09:31 PM | #17 |
Thanks. email on its way.
Mike K. |
01-21-2019, 09:37 PM | #18 |
Thanks for the pics. I am new to this form of communication, and don't know what a PM is....clarify please. Pete says he has a pair in nice condition so don't grind off the rivets just yet.
01-21-2019, 09:41 PM | #19 |
PM is a private message
01-21-2019, 09:42 PM | #20 |
PM is a private message. Please click on the name of the member you want to message and then click on the private message feature.
