Old 11-15-2021, 11:47 PM   #1
Barnwood
Default What type of grease should I use for an A-17270-FL speedometer gear case?
Barnwood is offline   Reply With Quote
Old 11-16-2021, 08:14 AM   #2
chrs1961815
chrs1961815's Avatar
Default Re: What type of grease should I use for an A-17270-FL speedometer gear case?
I would either use mystic 6 grease or Timken Bearing grease since it sees a lot of rotation (though these gears are very hard to wear out).
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
