Old 05-24-2018, 06:53 AM   #1
spinelll
spinelll's Avatar
Default Rattle Can Straw
I realize that the color "straw" has many variations.
Having said that, does anyone know of a specific rattle can brand and color that comes close to this pic? The "clean" area of course.
Thanks
Len
spinelll is offline   Reply With Quote
Old 05-24-2018, 08:00 AM   #2
Big hammer
Default Re: Rattle Can Straw
I had a automotive paint store tell me they could mix paint and put it in a spray can.
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 05-24-2018, 09:42 AM   #3
Tacoma Bob
Tacoma Bob's Avatar
Same here. Told my paint supply guy I needed Lombard blue. He did a quick search and used his color meter and put it in a spray can. Not particularly cheap though.
Tacoma Bob is offline   Reply With Quote
Old 05-24-2018, 09:45 AM   #4
marty in Ohio
marty in Ohio's Avatar
Same here in Elyria, Ohio. Our auto paint store told me it could be done for about $25.00 per can.
Marty
marty in Ohio is offline   Reply With Quote
Old 05-24-2018, 10:14 AM   #5
bucket-o-rust
Go to your nearest auto body repair shop and ask where they buy their supplies.
like paint primer and sandpaper. Then take your wheel to that shop and they will match your paint perfectly and put it in a rattle can that will work better than most over the counter rattle cans. Not all shops have that kind of equipment so you will have to find one that does.
bucket-o-rust is offline   Reply With Quote
Old 05-24-2018, 11:05 AM   #6
29spcoupe
29spcoupe's Avatar
Rustoleum Almond is very, very close. I used it on my wheels, needs at least 2 coats.
29spcoupe is offline   Reply With Quote
Old 05-24-2018, 12:47 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
http://duck-walk.com/rust-oleum-pain...s-color-spray/
Old 05-25-2018, 12:24 AM   #8
Y-Blockhead
Y-Blockhead's Avatar
I use Krylon 'Buttercream' for touchups on my wheels. It matches my 'Straw' wheels pretty closely. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Last edited by Y-Blockhead; 06-03-2018 at 10:37 AM. Reason: Corrected spelling due to FAT FINGERS...
Old 05-25-2018, 11:25 AM   #9
oldman - NorCal
oldman - NorCal's Avatar
I also took the painted portion of the '31 upper radiator shell into an automotive paint store and had them match it up into a can of spray paint. Took about 10 minutes and as far as I was concerned, a perfect match.
oldman - NorCal is offline   Reply With Quote
Old 05-25-2018, 07:49 PM   #10
Houdini
Houdini's Avatar
I was looking to paint my wheels the light yellow look that they call Tacoma Wheat in later years and earlier called Straw (I think), but it is a light yellow and not the off white that your picture shows.
I did a bunch of looking and trying and then found a perfect match for what looked to be Tacoma Wheat and Straw in some pictures. Again this has that light yellow look
I found it in Home Depot, as others didn't carry it.
It's Rustoleum Painters touch 2X Warm Yellow gloss and I like the way mine came out. Since it doesn't cost much, if you think this is the color you are looking for, you might buy a can and give it a try. The gloss makes it look really nice and likely more durable that flat.
Houdini is offline   Reply With Quote
Old 05-26-2018, 07:01 AM   #11
marty in Ohio
I did the same as Houdini. I'm pretty much color blind, especially before the cataract surgeries, but my wife is an artist. We took the original color charts to the Rural King store and she found the Warm Yellow Gloss Rustoleum the closest.
Marty
Old 05-26-2018, 07:46 PM   #12
modelAsteve
modelAsteve's Avatar
Yes, this color was invented by my grandfather.
Thanks for asking!
Steve Straw
modelAsteve is offline   Reply With Quote
Old 05-28-2018, 09:06 AM   #13
eagle
eagle's Avatar
Smile Re: Rattle Can Straw
Thanks for asking!
Steve Straw
Did he invent the Straw Berry as well?
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 05-28-2018, 10:51 AM   #14
chap52
chap52's Avatar
Get the color mixed , thin it a bit and use an air brush for small areas. Then after it dries wet sand it down to 2000 grit. Blends in well.
chap52 is offline   Reply With Quote
Old 05-28-2018, 08:10 PM   #15
walls
https://www.66autocolor.com/touch-up...aint-s/320.htm
I’ve bought paint from this website before, little pricey, but it’s good stuff.
walls is offline   Reply With Quote
