Old 07-23-2019, 03:30 PM   #1
Tim Brown
Tim Brown's Avatar
Default Help! Why is there excess oil in a crab dist?
Heres the deal, 49-53 merc block, 59A style cam and crab 2 bolt dist.
Every time we drive the car (34 3w) for a short while, the crab cap and rotor get bathed in motor oil fouling the electrical system.
More info: 59A style intake with fuel pump and breather mounted above.
Any ideas on this one?
Stumped...
Tim Brown is offline   Reply With Quote
Old 07-23-2019, 05:41 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: Help! Why is there excess oil in a crab dist?
I get this quite a bit, as there isnt any main feed of oil to the timing cover , i think its got to be crankcase pressure caused by lack of ventilation. Check fresh air vent etc... Try removing the vacuum brake line for testing as well........
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 07-23-2019, 06:12 PM   #3
Tony, NY
Check out this old thread. You may find some answers.
https://www.fordbarn.com/forum/showthread.php?t=146772
Tony, NY is offline   Reply With Quote
Old 07-23-2019, 06:15 PM   #4
svm99
Somebody can check me on this.......seems 59A timing gears cut opposite to 8BA gears so that one set moves oil opposite of the other set?
Which gearset do you have Tim?
svm99 is offline   Reply With Quote
Old 07-23-2019, 06:33 PM   #5
Tim Brown
Tim Brown's Avatar
I’m also wondering if there could be too much oil in it. It’s got a full flow conversion on it and unknown origin of the dipstick.
Old 07-23-2019, 06:44 PM   #6
JSeery
JSeery's Avatar
Don't use the dipstick to determine initial oil level. Dain the oil and add five qts. Check it with the dipstick and see where it is at. Mark the dipstick at the 5qt level.
Old 07-23-2019, 08:12 PM   #7
Tim Brown
Tim Brown's Avatar
Originally Posted by JSeery View Post
Don't use the dipstick to determine initial oil level. Dain the oil and add five qts. Check it with the dipstick and see where it is at. Mark the dipstick at the 5qt levels.
That’s where it is right now.
Old 07-23-2019, 08:47 PM   #8
JSeery
JSeery's Avatar
Ok, I'm confused. Thought you stated that the dipstick was of unknown origin. If you know the dipstick is correct then why the concern of being overfilled?
Old 07-23-2019, 10:05 PM   #9
Brian
Brian's Avatar
If you examine the timing cover you should find 2 little oil holes in the recess for the distributor; one at top to let oil in, and a larger one at the bottom to allow oil to drain back into engine. Check that the return hole is open....
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 07-23-2019, 10:13 PM   #10
Tim Brown
Tim Brown's Avatar
Sorry for the confusion. I have 5 quarts in it and put a new mark on the dipstick.
Old 07-23-2019, 11:10 PM   #11
deuce_roadster
deuce_roadster's Avatar
What Brian said x2. Also, is there too much clearance in the back bushing?
Old 07-24-2019, 01:14 AM   #12
flatheadmurre
flatheadmurre's Avatar
I had it a couple of times when people haven´t understood that the bushing absorbs oil and have drilled oil holes through it...
Or someone took the oilwick inside the shaft out while cleaning...
Old 07-24-2019, 09:42 AM   #13
Bored&Stroked
Bored&Stroked's Avatar
Stumped...
Is this a newly built engine? What is the oil pressure like?
Old 07-24-2019, 10:02 AM   #14
Tim Brown
Tim Brown's Avatar
Thanks everyone. I’ll have a look at it tomorrow evening and report back ... T
Old 07-24-2019, 03:57 PM   #15
FlatheadTed
FlatheadTed's Avatar
Another thing to look at, a high pressure oil pump could override the relief valve in the valley ,the valve opens occasionally to lube the timing gears and the back of the distributor ,Most distributors that I have worked on do not have holes drilled at the rear bush possible to reduce this problem .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Thread Tools
Display Modes
