Old 12-11-2021, 06:14 PM   #1
Duke
Default Driveshaft bearing wear
Is this too much wear on the shaft surface?
Thank you
File Type: jpeg C5E357CD-7F21-4C74-8D83-5B8B299455EE.jpeg (83.4 KB, 92 views)
Duke is offline   Reply With Quote
Old 12-11-2021, 06:30 PM   #2
Phil Gillespie
Phil Gillespie's Avatar
Default Re: Driveshaft bearing wear
Perhaps to measure worn surface area and compare to good shaft surface.
Seem to remember there is a wear limit calculated on diameters.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 12-12-2021, 05:34 PM   #3
19Fordy
19Fordy's Avatar
When I replaced my 1940 Ford torque tube center bearing I also noticed a little wear but realized that the torque tube bearing was not a tight fit around the drive shaft and served mainly to prevent "whipping" of the driveshaft. Therefore, I didn't replace the drive draft.
The first two photos show the OEM bearing minus the rubber encasing which literally dissolved away. Lst photo shows OEM Ford torque tube bearing placed on shaft. It's a sliding fit. There is a leather seal on each side of the OEM bearing.
Old 12-12-2021, 06:24 PM   #4
Brian
Brian's Avatar
Actually, that looks pretty good. Although hardened rollers run on that, the shaft is not heat treated; you can file it.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 12-12-2021, 11:38 PM   #5
cadillac512
cadillac512's Avatar
It looks fine to me, Duke. If the wear was serious the reflected lines of light on the surface of the shaft would appear to have a wave or jog where the wear occurs. I don't see any at all.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 12-13-2021, 07:45 PM   #6
Duke
Thank you! The batteries died in my calipers and there is no stock in town.
Old 12-13-2021, 08:29 PM   #7
GB SISSON
GB SISSON's Avatar
Terry
Your quote seems to reflect some of Mr. Yunick's Country Smarts. Good observation'
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
