Old 05-18-2017, 06:43 PM   #1
mll1446
Default 1947 mercury brake issue?
on a 47 mercury when drive car the car runs an d stops but when slow down or put clutch in it stops or binds up doesn't roll.
attached is a pic of brake drum it has a groove in inside is this correct? or is drum going to far in o to brake shoes any help appreciate
is there anything that would cause drum to run on hub?
mll1446 is offline   Reply With Quote
Old 05-18-2017, 06:47 PM   #2
mll1446
Default Re: 1947 mercury brake issue?
more pics of brakes
Old 05-20-2017, 12:26 PM   #3
grumppyoldman
grumppyoldman's Avatar
I haven't seen the brake system on a Merc. but the way the back plate is setting doesn't look right. My 48 Ford had the wheel cyl. at the top, and emergency brake cable on the bottom. Could the back plate be installed wrong? That could cause some problems. Al
grumppyoldman is offline   Reply With Quote
Old 05-20-2017, 12:36 PM   #4
JSeery
JSeery's Avatar
Does this look better to you? LOL The jack stand should give you a hint. It does look like the drum is locating to far inboard. (Deleted incorrect comment!!)
Old 05-20-2017, 02:00 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by JSeery View Post
It does look like the drum is locating to far inboard. Might check to see if the proper bearing is installed in the hub.
If the drum is seating too far inboard, that has nothing to do with the bearing. That drum HUB seating is determined by the axle's taper/hub fitment. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 05-20-2017, 03:58 PM   #6
grumppyoldman
yes a little trick photography, I see the axle bumper is also tilted to the left. Must have it parked on a wall. LOL Al
Old 05-20-2017, 04:30 PM   #7
JSeery
JSeery's Avatar
LOL, Yep, brain dead! Was thinking of front drums!!!
Old 05-20-2017, 05:36 PM   #8
rich b
rich b's Avatar
Strange that there would be a groove there that leaves that ridge on the outer edge of the lining. The inner side of the drum usually is flat all the way across. Also; noticed there appears to be some pretty thick shims between the shoe and the lining. Have you measured the ID on the drums.
Going back to your problem; any more details? Do any of the brakes get hot while driving, does the brake pedal (and master cyl) return fully, what made you pull this particular drum?
rich b is offline   Reply With Quote
Old 05-20-2017, 06:40 PM   #9
A bones
A bones's Avatar
So am I to understand that the problem shows up when you depress the clutch pedal?
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 06-07-2017, 07:44 PM   #10
mll1446
Old 06-07-2017, 11:22 PM   #11
rich b
rich b's Avatar
If the brakes are getting hot and drag while driving; but seem properly adjusted when cool, I would check that the return spring is good and that the brake pedal is returning all the way and that there is slight play between the push-rod and master cylinder. If that seems right, also check that the master cylinder piston itself is actually returning fully.
Those shims between the shoe and the lining; would still make me interested to check that the drums aren't oversize.
Old 06-08-2017, 12:00 PM   #12
grumppyoldman
If i'm understanding what is going on, there is a groove at the back in the drum where something is rubbing. My 41 Ford is doing the same thing, but the shoes do not show any sign's of rubbing. If it were shoe contact, there should be some sign on the shoe. I had the drums turned and the machinist hit the back and made it look the same as before. Did you have the drums turned?
Old 06-08-2017, 12:13 PM   #13
19Fordy
19Fordy's Avatar
How wide are your brake shoes, 1 3/4 or 2 in?
Compare this with the width of the machined brake shoe width of your drums.
