05-16-2017, 06:01 PM | #41 |
Re: 1953 ford 6cyl timing
05-16-2017, 06:04 PM | #42 |
let me get that will get back. to u
05-16-2017, 06:07 PM | #43 |
see pic
05-16-2017, 06:11 PM | #44 |
I'm not totally familiar with this distributor, but I don't see a ground wire to the points. 12264 in the first photo I believe. It may be connected to the other screw on your distributor, not sure how much difference that would make.
05-17-2017, 06:13 AM | #45 |
The points ground themselves to the distributor. When the wire from the coil is grounded it will charge the coil. When the points open the coil discharges creating the spark. If you put a test light on the coil post with the wire going to the dist you will see it light up when the points open and go off when the close. This is because the current like the path of least resistance, which is ground. If that is happening and the point gap looks correct then go to the condenser.
you put on a new cap so you also need to make sure the wires coincide with the firing order. Here is also a problem in an 8ba distributor. the wire in the distributor chafes and the insulation comes off and it gets grounded. This is below the dist plate.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
05-17-2017, 11:37 AM | #46 |
05-17-2017, 01:15 PM | #47 |
im sorry at a lost for what clip you are referring to
05-17-2017, 03:02 PM | #48 |
See red circle.
Bob |
05-17-2017, 03:15 PM | #49 |
The clip is laying at the 4:00 position in both pictures. It belongs on the shaft to hold the rotor tightly. Without the clip yours must feel loose on the shaft.
The sixes have timing marks on the crank pulley. Find TDC feeling the compression stroke thee line up the marks. The rotor position will be at #1. The firing order is 1 5 3 6 2 4. rotation is clockwise. Point gap is .024 - .026. Set them when the points are opened by the cam lobe. To Frank Millers point be sure to check the wire from the coil to the points. That is a rather common problem due to movement of the breaker plate.
You are never to old to enjoy your childhood. Forty1fordpickup on the HAMB. Last edited by 41ford1; 05-17-2017 at 03:17 PM. Reason: Spell check got me. |
05-17-2017, 03:16 PM | #50 |
05-17-2017, 04:08 PM | #51 |
this clip on right
05-17-2017, 04:10 PM | #52 |
Yes.
You are never to old to enjoy your childhood. Forty1fordpickup on the HAMB. |
05-17-2017, 04:14 PM | #53 |
thank you all i put the clip on and she started right up thank you thank you thank you
05-18-2017, 07:20 AM | #54 |
Thanks for the update. And now you probably know more about ignition systems than you planned on.
05-18-2017, 08:23 AM | #55 |
I know more now than I thought I ever know
05-18-2017, 08:57 AM | #56 |
sometimes it is the simple things.like you said at least you now know a little more than when you started a simple task.I am sure there were some who thought that I was crazy.
