01-31-2020, 07:16 PM | #1 |
French 17 stud oil and water pumps
I have a complicated query. I have the attached French-made Ford Comète. It is in good cosmetic shape (ex-museum) but the engine is weak, with low compression.
I was able to find a full gasket set but my mechanic does not want to disassemble the engine until I find him new water and oil pumps. I found images for those on the web, from another owner. My question is, can new ones of these be obtained? Are they standard 17-stud parts or did the French install something different than US engines? Many thanks, A Elam |
01-31-2020, 07:41 PM | #2 |
Re: French 17 stud oil and water pumps
The oil pump is the main bearing cap---- just the gears are replaced, you would have to measure them to see if the same as American 60hp, the drive gear is hard to find in USA, I have found them but not common
You should mention your location The water pump is not the same as USA engines If you post some of the dimensions I can compare to what I have |
01-31-2020, 10:56 PM | #3 | |
There is a mechanic in France who rebuilds water pumps for this engine (you send in the old one, he sends a ready rebuilt one when received). They cost $180 each. Don’t know if that is an OK cost. |
02-01-2020, 07:46 AM | #4 |
I live in France and maybe able to help you.Does your car also have the full synchro 4 speed transmission?
02-02-2020, 03:45 AM | #5 |
A french society called. Technitacot sell water pumps . Try to contact the ,club vedette but they are'nt very quick to answer to non club members.
02-02-2020, 05:53 AM | #6 |
02-02-2020, 07:26 AM | #7 |
Today i was getting a pulley for a waterpump and found this one in the shelfs...looks new and the red ford tag is literally falling apart...
If it can solve your problems make me an offer... |
02-05-2020, 05:58 AM | #8 |
That's a nice car!
