08-03-2020, 01:38 PM | #1 |
Installing headlight bar
I am restoring my 1930 sedan and couldn't get the headlight bar installed because the fenders where "relaxed" and needed to be compressed down. I couldn't find a post that talked about this and I didn't have 2 friends available to lay on the fenders to push them down. After I got the bolt through the edge of the fender and hoop, I took a couple of ratchet straps and wrapped it around the fender hoops and the tire trays. Then I was able to ratchet the fenders into place and get the headlight bar bottom bolts into place. I reamed out the bolt holes first with a drill bit that was slightly larger than the bolt. Worked like a dream!
08-03-2020, 02:54 PM | #2 |
Re: Installing headlight bar
I had the same problem with my 29 Tudor. I loosened the bolts holding the fender brackets to the frame, bolted everything up loosely, then tightened all of the bolts. Whatever works.
08-03-2020, 03:04 PM | #3 |
You have to loosen the braces. The headlight bar is basically a part of them. It ties the two together and adds extra strength to itself and them. It is supposed to be a tight fit.
"The more things change, the more they stay the same." |
08-03-2020, 07:23 PM | #4 |
Same advice as above, also loosen or remove the bolts that holds the fender braces to the outer lip of the fender.
08-03-2020, 07:51 PM | #5 |
Loosen the brackets where they mount to the frame, then install the bar.
08-04-2020, 11:50 AM | #6 |
