02-24-2015, 03:51 AM | #1 |
overheating 53
A friend has a 53 fordor that is running hot. Reconditioned engine about 6 years ago, runs nice. new radiator core and hoses about 3 months ago. Engine runs at the top end of the 'normal' range at 50 mph, on a day of about 23 degrees celsius. Increase speed to 60 mph and the temp starts to climb, and very quickly reaches 'hot'. There is no loss of water and no steaming, but then again, he slows down and the temp starts to go down. The engine/ car is completely stock with no modifications. Any of you fellows come across this, or have any ideas?? Thanks.
02-24-2015, 07:48 AM | #2 |
Re: overheating 53
Are the water pumps orig?
02-24-2015, 07:58 AM | #3 |
Re: overheating 53
Sounds like a timing Problem >>>
02-24-2015, 08:57 AM | #4 |
Re: overheating 53
Don't assume that the original gauge is reading correct temp's.
Check temp's with mech. gauge or other methods to find out what the actual temp's are.
02-24-2015, 10:41 AM | #5 |
Re: overheating 53
There was a thread recently about engine temps and some of folks posted the reading they got off of the engines using an IR sensor. Very interesting.
I picked up one on e-bay for less than $20 |
02-24-2015, 10:53 AM | #6 |
Re: overheating 53
Imagination is more important than knowledge. |
02-24-2015, 01:28 PM | #7 |
Re: overheating 53
Gordon ,Like the others it can be the gauge or any of the above but this can also happen when the radiator core design is not dispersing enough heat ,if its un pressurised add a 3-4 lb header tank or valve . As well try a shroud you should notice a difference .Ted
02-25-2015, 02:42 AM | #8 |
Re: overheating 53
Simple stuff first.
As Bill said, check the timing. On a loadamatic dizzy, I would also have a little suck on the advance can tube to make sure it's moving the points plate, and hold the suck with your tongue, points plate should stay put, only returning when you release the suck. Take advance tube off the carb end for this. I have seen a couple of times, a new 97 sat on the top, or rebuilt 97 or pre 8BA 94 up there, and advance tube not connected just blocked off. This will not have any advance, as thus, the timing is retarded when it should be advanced. Retarded timing will heat that engine up. Martin. |
02-25-2015, 01:46 PM | #9 |
Re: overheating 53
My 53 Victoria had a heating problem, used mechanical gauges on both heads, didn't see ant difference to the one on the dash, my radiator had only 3 tubes spaced 3/4 inch apart. replaced with 4 tubes 1/2 inch apart. checked out after installing at 70mph in 95 degree weather the temperature ran 190 degrees. you may want to count your tubes in your radiator.
