Old 05-15-2019, 04:25 PM   #21
tubman
tubman's Avatar
Default Re: Crankshaft Timing Gear Install
Do it in the kitchen; the ovens right there and the heat is more controllable than a torch, plus the lighting's better.
I prefer a pipe over a brass drift, as the chances of getting the gear "cocked" on the shaft are eliminated (unless the end of the pipe is not square).
Old 05-15-2019, 04:46 PM   #22
flatford8
flatford8's Avatar
“Do it in the kitchen; the ovens right there and the heat is more controllable than a torch, plus the lighting's better.“
And the kitchen is where the fridge is, the fridge is where the beer is!!
If you get caught, better to beg forgiveness than ask permission...Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 05-15-2019, 09:43 PM   #23
Ronnieroadster
Ronnieroadster's Avatar
Heck for years I have been using an old toaster over just put the gear in at max heat for 15 minutes. It will expand just enough to begin going on then use the pipe to complete the installation. Works perfectly every time no damage to the gear and no raised metal between the two surfaces to cause a problem like metal shavings inside the engine if not cleaned properly. The toaster oven comes in handy to warm up cold pizza for lunch also.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
First Ford Flathead bodied roadster to run 200 MPH Record run July 13, 2018 LTA timing association 200.921 from a standing start in one and a half miles.
Old 05-17-2019, 12:16 PM   #24
macdonge
macdonge's Avatar
Done! Had the BFH and a big drift made up from pipe fittings as backup but it turned out, after heating the gear up to ~ 300 deg F, the gear slid right on! I just made sure it was tapped fully home using a brass hammer & drift. Thanks again to all for your replies!
Glen
macdonge is offline   Reply With Quote
