Old 03-23-2019, 09:35 PM   #21
stewgee
stewgee's Avatar
Default Re: Gas shutoff valve
Thank you guys for the suggestions here. Just one more question. What's a pencil filter? Is it a filter in the shutoff valve or in the tank?
stewgee is offline   Reply With Quote
Old 03-23-2019, 09:50 PM   #22
30 Closed Cab PU
Here is a link showing one. Is is inserted into the opening for gas in the top of the Shutoff, so sticks up into the tank when the shutoff is installed in the tank. To inspect/clean, the shutoff has to be removed from the gas tank. This is an accessory, the As did not come with the filters from the factory.
Debris in the tank has s tendency to damage the gas shutoff with the result being it leaks when the shutoff is off. The leak is not from the valve body in the interior, but causes the shutoff not to 100% turn off the gas supply to the carb.
https://www.brattons.com/fuel-tank-filter-screen.html
Old 03-24-2019, 12:17 AM   #23
Magicbox51
Magicbox51's Avatar
I drained the tank into a gas can from the gas line by disconnecting from the carb. I have a pencil filter so of course there is some left when it is otherwise drained. then, inside the car, I took out the mat and the floorboards knowing there would be some dripping of gas. While taking the valve off, I was careful to have a shallow can underneath to catch the remaining gas. Wear a short sleeve shirt as there will be some draining down onto your hand as you go. It's inevitable. Just do it in a ventilated space with no sparks or open flames. Once the remaining gas is drained, you're good to go. There were only a couple cups of gas remaining, so its not that much, but there will be some that gets on your hands and even down your arm, so make sure to have the floor out and you should be OK.
-Bill G
Magicbox51 is offline   Reply With Quote
Old 03-24-2019, 08:29 AM   #24
stewgee
stewgee's Avatar
Thumbs up Re: Gas shutoff valve
Got it.Thanks
Old 03-24-2019, 10:27 AM   #25
katy
katy's Avatar
Originally Posted by Mike Peters View Post
Benson: You are correct about pencil filters from vendors leaving some gas in the thank and then having to catch that last little bit whilst removing the shutoff valve.
Here's my home made pencil filters. Got the idea from another Model A buddy a couple years ago. You simply roll a piece of brass screen around the appropriate size drill bit to fit the intake side of the shutoff valve. Solder the seam and install in the shutoff. The tank will then drain the same as no pencil filter because there in no copper upright tube used as the commercial filters that you see in the catalogs. ALL the gas drains out and the screen stays put if you get the right diameter so it fits snugly in the shutoff. Gravity does the rest.
So, where does one get this screen w/the small mesh?
Any screen I've been able to source is loo large a mesh to capture water.
Talk slow, think fast.
Old 03-24-2019, 11:04 AM   #26
30 Closed Cab PU
I am curious where to get fine screen too.
I am not worried about water, the sediment bowl and screen should filter that out before it gets to the carb. Filtering sediment./grit/rust from the shutoff is more my concern. My A did not have the pencil screen, and debris wrecked a couple of shutoffs before I found out/learned here about what was causing my issues. During this also had issues with bad out of box shutoffs from venders before learned here to order shutoffs from Brattons.
Old 03-24-2019, 05:33 PM   #27
Mike Peters
Mike Peters's Avatar
https://www.darbywiremesh.com/brass-wire-mesh/
Here's one source. They handle any size mesh you want. The screen I used was given to me and unfortunately I do't know the source. Graingers? The mesh size I used is not real fine, but fine enough to keep the big stuff from plugging the shutoff valve and gas line. Don't use steel screen, because it will rust. Brass conforms easily to any shape you want, and is easy to solder.
Mike Peters is offline   Reply With Quote
Old 03-25-2019, 07:38 AM   #28
chap52
chap52's Avatar
Here is one the "Mike's" offers. Chap
https://www.mikes-afordable.com/product/A9193T.html
