Old 08-17-2019, 10:42 PM   #1
SteveR.
Default New clutch - should the throw out bearing disengage?
I just swapped engines and installed a new clutch. I adjusted the pressure plate fingers to 5/8” per Les Andrews. The clutch works fine, but with the cover off the top of the transmission I could see that the throw out bearing kept spinning even when I release the clutch with the car not in gear. Is this an issue? I assume it will cause more wear on the bearing, but honestly it would be very little since I rarely sit with the clutch out while idling.
The pressure plate had the adjustment bolts/nuts cut through the middle to lock them together, this put the fingers at about 1” from the pressure plate instead of 5/8”. I had to debut the nuts to get them to turn. I did stake them after adjusting.
SteveR. is offline   Reply With Quote
Old 08-17-2019, 11:07 PM   #2
Drive Shaft Dave
Default Re: New clutch - should the throw out bearing disengage?
Yes, if you are pushing the clutch pedal to the floor it will spin. how close is the throw out bearing when the pedal is released?
Drive Shaft Dave is offline   Reply With Quote
Old 08-18-2019, 05:55 AM   #3
Patrick L.
Patrick L.'s Avatar
If the throw-out bearing is touching the pressure plate fingers it will spin. Only once the pedal is released and the proper amount of free play is set will the bearing stop spinning. The pedal free play should be set to 1.0-1.5".
When setting the pressure plate fingers, the clutch assembly must all be bolted up to the flywheel. The fingers are then set to within .002" of each other.
Old 08-18-2019, 06:49 AM   #4
SteveR.
Sorry, I misspoke. The throwout bearing still spins when I release the clutch and the transmission is not in gear. - edited my original post.
Old 08-18-2019, 07:14 AM   #5
kenparker
kenparker's Avatar
Try a newangle of explanation. When the pedal is released and your foot is off the pedal the throwout bearing should NOT spin. Continued spinning at this stage will create premature wearout.
As you press the clutch pedal toward the floor, the first 1 to 1.5 inches is "free play". This is the movement of the throwout bearing toward the PP fingers - before they touch. Once the to bearing touches the fingers it should begin spinning.
kenparker is offline   Reply With Quote
Old 08-18-2019, 11:06 AM   #6
SteveR.
Thanks Ken, the throwout bearing is still spinning with my foot off the pedal. Is there any method of adjustment other than adjusting the pressure plate fingers?
Old 08-18-2019, 11:31 AM   #7
Patrick L.
Patrick L.'s Avatar
Measure the pedal freeplay. Its how far the pedal moves easily before any resistance is felt. As said, it should be 1.0-1.5".
This is adjusted by changing the length of the linkage between the pedal end and the bell housing shaft arm.
The clutch pedal should return fully on its own.
Old 08-18-2019, 12:33 PM   #8
kenparker
kenparker's Avatar
Follow Patricks advice. Free Play should be 1 to 1.5". Adjust free play at the adjustable link between the pedal end and the arm on the bell housing.
watching thru the inspection hole the Fork that operates the TO should come all way back til it touches the face of the Transmission bearing reatiner.. As you press pedal down the TO will move forward ti lit touches the fingers. The least amount of touch to the fingers will make the TO spin.
Is the spring that pulls the TO and its carrier and its carrier in place. That spring IS IMPORTANT.
Old 08-18-2019, 12:49 PM   #9
1955cj5
1955cj5's Avatar
You can adjust pedal freeplay by screwing the clutch pedal adjusting yoke in or out of the trunion.
Look at page 1-69 in Les Andrews' book.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-18-2019, 03:01 PM   #10
mike657894
mike657894's Avatar
I have seen 3/4in and 7/8in as recommended measurements. not every clutch disc,pressure plate, fly wheel, throw out bearing is going to be the same thickness. And I think the gap shrinks with clutch wear. you could attempt to tighten the nuts and keep turns consistent around the circle by counting flats/turns on the nuts. go one turn at a time until the bearing stops spinning.
mike657894 is offline   Reply With Quote
Old 08-18-2019, 10:35 PM   #11
SteveR.
Thank you so much everyone, adjusting the yoke fixed it easily. Thank you! Now to fix the oil leaks...
Old 08-19-2019, 05:49 AM   #12
Patrick L.
Patrick L.'s Avatar
Fixing your oil leaks ? That could be a life long task ! Good luck. Most 'As' don't really leak, they just mark their territory.
Old 08-19-2019, 06:58 AM   #13
kenparker
kenparker's Avatar
oil leak? Where?
Old 08-19-2019, 04:03 PM   #14
Mulletwagon
Mulletwagon's Avatar
That's just the way As lubricate the seals (LOL).
Mulletwagon is offline   Reply With Quote
Old 08-19-2019, 05:28 PM   #15
Bill G
Bill G's Avatar
It's also the way it lubricates your driveway, garage and the street!
