09-17-2018, 02:59 PM | #1 |
What’s stronger
Pc7 or jb weld.
I like that pc 7 is thinner. The shaft that the wiper arm attaches is damaged and won’t hold the arm. I don’t want to purchase a new motor. Which would you use?
Thanks - 30-9 1939, 1940 |
09-17-2018, 03:08 PM | #2 |
Re: What’s stronger
Neither is probably suited to the task. You're on your own, it is impossible to make a recommendation.
Is there no way to fit a better unit? Mart. |
09-17-2018, 03:25 PM | #3 |
Re: What’s stronger
The arm is solid. The problem is the arm is slipping as the wiper moves back and forth.
09-17-2018, 03:54 PM | #4 |
Re: What’s stronger
The nut may be bottoming out, try adding a suitable washer under it to see if it will tighten on the tapered spline.
Or if it's bottoming on the threaded end, remove material from the threaded end.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 09-18-2018 at 05:21 AM. |
09-18-2018, 04:00 PM | #5 |
Re: What’s stronger
PC-7 You can mold it better than J-B Weld has been my experience |
09-18-2018, 06:03 PM | #6 |
Re: What’s stronger
09-19-2018, 01:07 PM | #7 |
Re: What’s stronger
Are you wanting to bond the arm to the shaft, or build up the shaft so that an interference with the arm can be achieved?
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
09-19-2018, 01:33 PM | #8 |
Re: What’s stronger
Thanks gents
Bond is goal
09-19-2018, 03:18 PM | #9 |
Re: What’s stronger
If this is so you can put the epoxy on the damaged shaft and then a daub of grease in the nut and it can be removed later if need be. I have used this method on gearshift knobs when the threads are damaged.
09-19-2018, 05:29 PM | #10 |
Re: What’s stronger
I have made tapered tin shims----beer can etc to repair worn wiper arm fits
