12-24-2017, 05:53 PM | #1 |
King Sealy
Anybody have a good source for King Sealy sending unit for a gas gauge like in a 36 Ford? Thanks Ford Barners..!!
12-24-2017, 06:18 PM | #2 |
Re: King Sealy
I have found that you can use a 1940's and 1950's Ford or Mercury 6V gas tank sending unit to replace the OEM 1940 Ford gas tank sending unit. What you have to do is remove the top of the sending unit and adjust the little starwheel to make it match the OEM King Sealy dash gauge. Turning the star wheel CW makes the needle go to the FULL side and CW makes it register to the Empty side of the dash gauge. Perhaps you could do the same with a broken 1936 gas tank unit. You can use a 6V dry cell battery as a power source.
12-24-2017, 11:52 PM | #3 |
Re: King Sealy
19Fordy...perhaps CCW for the Empty side???
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
12-25-2017, 06:52 AM | #4 |
Re: King Sealy
My problem is that I do not have a sending unit and need one but from what I have read about the aftermarket ones do not work? Thanks
12-25-2017, 07:22 AM | #5 |
Re: King Sealy
Suggest you post this in The Swap Meet, too.
12-25-2017, 08:09 AM | #6 |
Re: King Sealy
