05-29-2019, 02:07 PM | #1 |
29 ccpu sun visor cover
I bought a sun visor cover from Mikes for an original frame, the frame has 2 tabs sticking up on each side, do they poke through the cover, then is there a sheet metal strip that goes over the tabs and gets bent down?
The kit comes with 12 pic's and instructions, the first instruction says, attach thin cloth to the top of visor frame using contact adhesive, what type of fabric should I use? and what type glue? thanks nick c |
05-29-2019, 02:44 PM | #2 |
Re: 29 ccpu sun visor cover
There is a sheet metal strip for each side with holes for the tabs as you mentioned. The tabs go through the fabric and then the strips help hold everything in place.
I don't remember where I got these.....they did not come with the visor kit.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 05-29-2019 at 02:53 PM. |
05-29-2019, 02:46 PM | #3 |
Nick, yes, there is a metal strip and tabs that bend over the strip on the original visors. Here's a photo.
I used contact cement years ago on this one and it held up fine. For the cloth over the visor frame use something with a little substance, I used some old denim, probably from some of my old levis and it worked great. You could also use some of the cotton duck that is used in the top of the 82-A. -DAN |
05-30-2019, 07:36 AM | #4 | |
Nick, in the industry we use a product called Weldwood Landau Top adhesive. This is a yellow glue that is sprayed from a gun however it can be brushed also. I am curious how the instructions suggest to sew the fabric on the inside of the frame as shown in Dan's photo. |
05-30-2019, 12:07 PM | #5 |
Brent, the replacement visor covers I have seen have all had the stiches on both sides of the cover, and after it's mounted and glued together it gives the appearance of being sewed together.
In addition to that, the replacement visors have the stiches squared off in the corners. The original visors were covered and sewn together after the cover was mounted, this left the stiches rounded in the corners. -DAN |
05-30-2019, 12:19 PM | #6 | |
Yes, I knew that hence the reason I was asking. I had not seen the sewing method like you described however I also have a Singer long arm sewing machine where we do it correctly as Ford did on those, so I really had not inquired how others were doing it. |
05-30-2019, 03:19 PM | #7 |
I figured you knew the proper way to do the visors, and it's good to know there is a place to have it done correctly.
The visor in my photo was a kit from Lebaron Bonney from about 1971. The fit was excellent on my original frame, it would make a good pattern for a new one. -DAN |
05-31-2019, 04:25 PM | #8 |
Mine was all glued and did not come with any stitching, I did not think it was fun to install. Would anyone suggest a thin bead of caulking between the visor and the wood header where the 7 screw are?
thanks nick c |
