Old 12-06-2016, 12:46 PM   #1
Roger/Sacramento
Roger/Sacramento's Avatar
Default Water capacity of motor and radiator
I have distilled water only in my pickup. Am sending it to an area that has freezing temperatures. Want to add antifreeze. What ratio of water to antifreeze? What is the total capacity of liquid?
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 12-06-2016, 01:01 PM   #2
Ross F-1
Ross F-1's Avatar
Default Re: Water capacity of motor and radiator
A gallon of antifreeze to replace a gallon of water in the system should put you where you are protected to well below zero F.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 12-06-2016, 01:28 PM   #3
Roger/Sacramento
Thanks.....that is what I will do.
Old 12-06-2016, 01:43 PM   #4
V8 Bob
V8 Bob's Avatar
Most/all antifreeze containers have a chart showing the amount needed for a particular temperature.
A very good and easy to remember ratio is 50/50 water/antifreeze, resulting in about -35 F protection, along with very good rust prevention and increased boiling point. Since most flathead powered vehicles have 20 to 22 quart cooling systems, a minimum of 2 1/2 gallons of antifreeze would be needed, but it really depends on how much protection your pickup needs.
I pre-mix coolant for all my vehicles so I always have 50/50 regardless of their individual capacities.
Old 12-06-2016, 11:45 PM   #5
Mike in AZ
Mike in AZ's Avatar
and if you're not sure about the strength of your mix, you can buy an expensive tester at your local parts store....Mike
Mike in AZ is offline   Reply With Quote
Old 12-07-2016, 12:06 AM   #6
tubman
tubman's Avatar
I think you meant to say "inexpensive".
Old 12-07-2016, 12:45 AM   #7
Ross F-1
Ross F-1's Avatar
Here's a typical chart. I assumed the same 20 - 22 qt capacity when I said to put in a gallon, which would be about a 20% mix. Gives protection down to about (-8) deg Celsius, I read off the wrong scale! So yeah, you probably want a little more than a gallon in there.
