Old 03-17-2019, 09:17 PM   #1
Bigjohnson
Default Fan hub
Would any one know what oil an how much goes in fan hub thanks
Bigjohnson is offline   Reply With Quote
Old 03-17-2019, 09:25 PM   #2
Tinker
Tinker's Avatar
Default Re: Fan hub
On a general opinion, not knowing your car yr or gen.
A couple drops when you do a oil change is standard procedure. Whatever you do an oil change with is fine.
Old 03-17-2019, 09:46 PM   #3
Bigjohnson
Default Re: Fan hub
I have a 35pu with a 59 at motor thanks for the help I took the fan hub apart to clean an paint no oil in hub how much when dry thanks
Old 03-17-2019, 09:50 PM   #4
Tinker
Tinker's Avatar
Default Re: Fan hub
Just oil the hard bearings when installing, or add some oil to the cup. It doesn't take a lot.
You could put some lithium grease on it when installing.
Old 03-17-2019, 09:53 PM   #5
Bigjohnson
Default Re: Fan hub
Thanks for the info
Old 03-17-2019, 09:58 PM   #6
MGG
MGG's Avatar
Default Re: Fan hub
Scroll down the list of threads and you will come to one titled "oil bath fan hub". The last post was yesterday so it is not very far down the list. This thread has a lot of information about servicing the hub, especially the post by Van Pelt sales.
MGG is offline   Reply With Quote
Old 03-17-2019, 10:03 PM   #7
Tinker
Tinker's Avatar
Default Re: Fan hub
https://www.fordbarn.com/forum/showthread.php?t=260348
I run old style bearings and redid mine. Probably 60 yrs since the last time it was changed.
Old 03-18-2019, 11:04 AM   #8
Bob C
Default Re: Fan hub
To answer your question. "Add 1oz of engine oil turn fan until oil hole
is at bottom, draining excess oil."
Bob
Old 03-18-2019, 01:50 PM   #9
KGS
KGS's Avatar
Default Re: Fan hub
Bob
Ford originally recommended regular motor oil, but changed that later to 85-90 weight gear oil. The same gear oil used in your transmission.
l
KGS is offline   Reply With Quote
Thread Tools
Display Modes
