Old 02-03-2020, 11:02 AM   #1
russcc
Default Remote filter base.
Anyone have a Wix part # they have used for a remote oil filter ? And while we are at it , the correct Wix # for a filter that works with the flathead 95% oil filter system. Thank you Fordbarners.
russcc is offline   Reply With Quote
Old 02-03-2020, 11:18 AM   #2
V8 Bob
V8 Bob's Avatar
Default Re: Remote filter base.
There are several types of remote filter bases; single top or side in/out, dual side in/out, and dual filter, available from many sources like Summit, Jegs, Speedway, NAPA etc. The NAPA Gold/Wix filter #1515 crosses over to the Fram PH8A and works with all the remotes.
V8 Bob is offline   Reply With Quote
Old 02-03-2020, 11:18 AM   #3
Ronnie
Ronnie's Avatar
24762 wix remote mount for a 3/4 x 16 filter any brand a 51515 wix will work
list of bases https://www.wixfilters.com/Speciality/Conversion.aspx
R
Ronnie is offline   Reply With Quote
Old 02-03-2020, 03:32 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
There are a couple thousand listings on Ebay for remote filter mounts, just pick the one that will suit your needs.
https://www.ebay.com/sch/i.html?_fro...filter+adapter
And if you have to have a Wix, try this--
https://www.ebay.com/sch/i.html?_fro...l+filter+mount
Old 02-03-2020, 04:56 PM   #5
JSeery
JSeery's Avatar
Be sure you keep the IN and OUT connected to the correct ports on the block! IN on the filter bracket is the port for the original oil pressure gauge on the block. OUT on the filter bracket connects to the new hole drilled closer to the centerline.
Old 02-03-2020, 07:20 PM   #6
russcc
Thank you fordbarners. Looks like NAPA has the Wix 4770.
Old 02-03-2020, 08:14 PM   #7
Ronnie
Ronnie's Avatar
How did you arrive at a wix 4770?
R
