Old 02-09-2021, 06:07 PM   #1
normahlgrim
Default 1935 v8 engine, can a 1939/48 cam be used in it?
I want to know if I can do this before ordering a cam, I already have a two bolt distributor front cover on it. Thanks, Norm
normahlgrim is offline   Reply With Quote
Old 02-09-2021, 06:19 PM   #2
Andy
Default Re: 1935 v8 engine, can a 1939/48 cam be used in it?
It will fit and work but not exactly as new. Ford changed the valve angle. The later engines had the valves further from the cylinders. A later cam will have half the valves opening sooner and half later. I don’t know if it would be noticeable.
Andy is offline   Reply With Quote
Old 02-09-2021, 08:47 PM   #3
JSeery
JSeery's Avatar
I think there is some debate about if the cam timing was actually changed when the valve locations were moved.
Old 02-09-2021, 10:47 PM   #4
35fordtn
35fordtn's Avatar
I have used many 39-41 Cams in Early engines to take advantage of the bolt on cam gear with zero issues. Remember if you use the late 42-48 cam you would have to use a adapter to use the original 3 bolt distributor. But since you are using a two bolt timing cover itwould make best sense to use a 42-48 cam.. I have done such and noticed no issues. PS why is everyone so insistent with the two bolt distributor rather than a 3 bolt converted to later internals?
Old 02-10-2021, 12:49 AM   #5
cas3
my guess is the crab is shorter, and easier to fit in spaces like Av8's, or 8ba's in older cars. and, like my hero Bruce Lancaster said, "only 2 bolts, no vacuum line, the cap comes off with 2 clips, it can be removed in the dark with one wrench to fix it to get you home"
Old 02-11-2021, 03:54 PM   #6
normahlgrim
thanks, Norm
Old 02-11-2021, 10:41 PM   #7
Ol' Ron
Ol' Ron's Avatar
Not a problem. Just check the crank gear>>
