Old 03-27-2020, 07:18 PM   #1
dlfrisch
dlfrisch's Avatar
Default Spark/Gas Notched Plate
I have the steering column and (7 tooth) housing out on my work bench and while I’m installing a new upper bushing, bearing, spark/gas rods, horn/lights switch rod, I encountered a major problem. I can’t find the notched guide part, that the spark/gas rods ride on. We, my wife and I finished cleanIng the part, we set the unit down in the work area - waiting for it’s turn to be installed. When, I proceeded to reinstall it and fasten it to the upper bearing housing (steering tube). I CAN’T or COULD NOT FIND THIS NOTCHED PLATE part any where. It disappeared. We have searched the garage, house and work area - NG - maybe trashed by accident......this part can not be purchased. None of the parts dealers have it for sale. It’s probably the only Model A part, that can not be bought.
Does anyone have this part from old Model A parts or know of a possible salvage yard, that I can purchase or obtain this item ? It fastens on with two small flat head screws (6-32 x 1/4” ). I may have to buy a new steering assembly......I know, - what a dummy !
dlfrisch is offline   Reply With Quote
Old 03-27-2020, 07:47 PM   #2
160B
160B's Avatar
Default Re: Spark/Gas Notched Plate
Contact Berts Model A parts. They have a lot of original parts available.
https://modelastore.com/
800-321-1931
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 03-27-2020, 08:13 PM   #3
duke36
Is there a separate part for the 7 tooth steering housing? I thought the spark rod quadrants were separate for model T's but not A's. Steve at Berts' and Don at Snyders says there hasn't been demand for reproduction quadrants that can somehow be attached
to/ or replace the worn originals. There is a column on ebay that may fit your car for $45 plus shipping from Canada.
duke36 is offline   Reply With Quote
Old 03-27-2020, 08:17 PM   #4
dlfrisch
dlfrisch's Avatar
Thanks 160B. - I’ll call Berts. This has me real concerned. As per the other parts dealers - no one even supplies the whole steering column. I can’t imagine - I can’t find the part here in my garage and the fact that, no one sells a replacement. It’s an item that wares out. It don’t seem like I am alone with this situation.
Dave
Old 03-27-2020, 08:20 PM   #5
dlfrisch
dlfrisch's Avatar
Thanks l’ll look Duke36
Old 03-27-2020, 08:55 PM   #6
Sunnybrook Farm
Sunnybrook Farm's Avatar
There should be a bunch of these laying around as a lot of people switched from 7 to 2 tooth columns. I removed mine and put it on a Gimmer 2 tooth column. The 7 tooth doesn't have the rim around it that a 2 tooth does. Do you remember what it looks like, could be stuck on some other part laying around your shop?
Sunnybrook Farm is offline   Reply With Quote
Old 03-27-2020, 09:25 PM   #7
Gary WA
Gary WA's Avatar
I see it! it's right were you put it!!! Did you hang it up to paint it?
www.whidbeymodelaclub.com
Old 03-28-2020, 12:21 AM   #8
al's28/33
al's28/33's Avatar
Dave just call Berts they will have one. That's the first thing I had to replace on my Phaeton when I first got it. My original had one half broke off.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 03-28-2020, 03:50 PM   #9
dlfrisch
dlfrisch's Avatar
duke36. #3. - Thanks for your suggestion, to call Bert’s. They, did have my (lost) part in stock....wow, not a listed part with others.
Dave
Old 03-28-2020, 03:54 PM   #10
dlfrisch
dlfrisch's Avatar
Also, thanks to 160B. Berts, had my part.
Old 03-28-2020, 04:47 PM   #11
Y-Blockhead
Y-Blockhead's Avatar
Dave
Good you found what you needed. Bert's is one of the few vendors that sell used parts, that is why they had your part.
I bought some cowl light arms from Bert's a while back. The cowl light arms you get from the Vendors (Vintique Brand) don't even begin to work correctly.
