03-10-2014, 03:14 PM | #1 |
Help! How flat is flat enough?
I have two cast iron heads for my '35 21 stud engine. They both measure about .007 inches out of flat. (arched upward near the center) I have a nice cast iron surface plate to measure against. Should I pay $100 to $150 to have them surfaced or are they good enough to use? This will be a dead stock engine. 'advice appreciated. Jim
03-10-2014, 03:25 PM | #2 |
Re: Help! How flat is flat enough?
I think that you can run them... You may want to try this: put them face to face with a couple of bolts in their centers... Tighten them a bit, maybe 15-20 ft. lbs. Then measure the distance between them.
If you run them, retorqe a couple of times before loading the engine much... Please report back as to what you find. Karl |
03-10-2014, 03:29 PM | #3 |
This is exactly the way heads should be stored while an engine is apart.
Alan |
03-10-2014, 05:35 PM | #4 |
Makes perfect sense; didn't know that, thanks |
03-10-2014, 08:26 PM | #5 |
The gems we learn, thanks - didn't know it either.
03-10-2014, 08:32 PM | #6 |
What is the milling of a head for compression about..... (I was using a little sarcasm here) . Last edited by Tinker; 03-11-2014 at 08:31 AM. Reason: sp. |
03-11-2014, 05:33 AM | #7 | |
2nd, if you mill, cut, or scrape material of the head face, it reduces the combustion chamber volume, thereby increasing the compression ratio. Good for power, Good for economy good for efficiency. Peak power may not go up by much, but low end torque goes up very nicely, good seat of pants increase. Martin. |
03-11-2014, 06:05 AM | #8 |
If the "bow" is a slow, consistent, and gradual occurrence in the gasket face it will not be a problem.
03-11-2014, 07:56 AM | #9 |
generally .001 per cyl per head is max.but as jwl states there probably fine.
03-11-2014, 06:03 PM | #10 |
Thanks to everyone for the advise. This forum is a great way to get knowledgeable input overnight. I appreciate it very much. Jim
03-11-2014, 06:53 PM | #11 |
I don't bolt my heads together but I don't lay them flat either, they are stored on edge. In 56 I worked for a Packard Studabacker garage and we returned all the Packard parts to the factory. One Packard head had laied flat on a shelf for years and had a major bow in it. Laid them on edge ever since.
