Old 01-02-2018, 10:27 AM   #1
dudley32
dudley32's Avatar
Default '34 pickup fender braces
Does anyone reproduce 33-34 pickup front fender braces? Can a car brace be modified to work?...thanks dudley
dudley32 is offline   Reply With Quote
Old 01-02-2018, 12:19 PM   #2
Karl Wescott
Karl Wescott's Avatar
Default Re: '34 pickup fender braces
1933-34 Pickup front fender brace:
Not available reproduction (to the best of my knowledge).
Not similar to the passenger bracket. Do not start there.
Similar to 1932 front fender brace except with a "dogleg" near the base. If you are going to modify one that would be where to start. There is a very rough sketch in our catalog at http://wescottsauto.com/WebCatalog/C...ood-Fender.pdf.
Hope this helps
Karl Wescott is offline   Reply With Quote
Old 01-02-2018, 12:33 PM   #3
dudley32
dudley32's Avatar
thanks, that does help a lot...
Old 01-02-2018, 04:30 PM   #4
nickthebandit
1933-34 pickups and big trucks use the same fender brace.
nickthebandit is offline   Reply With Quote
Old 01-02-2018, 06:48 PM   #5
Newc
Newc's Avatar
Hi; They are available used in good shape. Start with a WANTED add, here on Fordbarn. I have a set for $185 + shp in Oregon. Newc
