02-26-2017, 10:07 PM | #1 |
How to Soften Old Hard Rubber Parts
I came across this solution a couple years ago on a motorcycle site, when a guy needed to soften the rubber coupling on his carb.
I needed to soften the rubber plunger for the pump on my old Crossman BB gun. Mix 1 part Wintergreen Oil to 3 parts rubbing alcohol and let it set in a closed container. I let my plunger set for at least a few weeks, and now it's soft as a new part. I'd guess this would work for hard original Model A hoses, and maybe belts, seals and O-rings. The local health store sells 10ml of the wintergreen oil for $30, but I bought mine on ebay for $1.69 with free delivery. |
02-26-2017, 11:04 PM | #2 |
Re: How to Soften Old Hard Rubber Parts
I think i remember reading a long time ago that pretroleum jelly softens rubber also. That may be common knowledge to some.
02-26-2017, 11:36 PM | #3 |
I also thought silicone lube spray letting parts soak in it gives them new life. I have heard the wintergreen trick in the past but good to get some conformation that it works!
02-26-2017, 11:49 PM | #4 |
02-27-2017, 12:02 AM | #5 |
WD-40 did it for me!
Pluck |
02-27-2017, 12:29 AM | #6 |
02-27-2017, 02:58 AM | #7 |
What does the softening is methyl salicylate, the main ingredient in wintergreen oil. This is cheaper than wintergreen, which is a natural product, as opposed to methyl salicylate which is a synthetic chemical used as a flavouring in drinks and an emollient for muscular pain.
I used to mount the local go kart track' racers' used tyres in a milk churn with half a cup of methyl salicylate in the bottom. After a week or two with the lid on the churn the vapours would permeate and soften the rubber for the next races A food flavoring company or chemical supply company should sell you a few hundred mls for a small sum. You want a technical grade not a high purity laboratory reagent grade which will be much more expensive. SAJ in NZ |
02-27-2017, 06:28 AM | #8 |
A wheel cylinder cup, overnight in DIP carb cleaner, makes a GREAT conversation piece!---It gets this l--------------------------------------------------l BIG!
Bill Useless
02-27-2017, 11:56 AM | #9 |
Tom, good information as always on numerous items. BTW you can go to the Crossman web site and look at the range of serial numbers for a particular model and from that get the part number for the plunger. The parts are very reasonable. On You Tube cam even see ways to increase the muzzle velocity.
02-27-2017, 12:11 PM | #10 | |
02-27-2017, 12:23 PM | #11 |
Guys I used to work with would put a little brake fluid in automatic transmissions to soften a leaky front seal. They didn't put much in but I don't know how much, so use caution. It did work!
02-27-2017, 01:35 PM | #12 | |
Brake fluid will soften rubber and enlarge it.. |
02-27-2017, 04:50 PM | #13 |
ARMOUR ALL, soak for a few weeks!
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
02-27-2017, 08:02 PM | #14 |
I find that Silicon works the best
02-27-2017, 08:57 PM | #15 |
We used lye water on milking machine tit-cups and hoses when I was a kid when my dad ran a dairy. Soaked them over night and everything was soft as new.
