05-17-2013, 04:50 PM | #1 |
Removing Radiator
Having a wild time removing radiator on my 31. (replacing 4 blade fan with new 2 blade) Thought I would have it boiled out while apart.
Seems it doesn't want to twist enough to clear the radiator tabs between the frame & fender. Would removing the shell and/or thin rubber pads under tabs give it move twisting room? I have the hood, front apron, headlight bar, water pump removed now. Thanks |
05-17-2013, 05:14 PM | #2 |
Re: Removing Radiator
Remove the shell.
05-17-2013, 11:36 PM | #3 |
05-18-2013, 04:13 PM | #4 |
