Old 06-26-2020, 05:08 PM   #1
corvette8n
corvette8n's Avatar
Default O/T paint can smoker question
I'm building a 1 gallon paint can smoker from some parts I had on hand, it doesn't seem to be putting out much smoke(using baby oil on the wick). My question is about the Nichome wire, I have about 28 turns of 20ga. wire wrapped around the wick reading about 5-6 ohms, does that seem right?
Old 06-26-2020, 06:49 PM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: O/T paint can smoker question
Well, if you're using a 6v, it's only about 6 watts---night light power
12v would be about 24 watts---should start smoking.
110v, 2000 watts. Really smoking & blowing fuses.
8^)
Jack E/NJ
Old 06-26-2020, 07:44 PM   #3
corvette8n
corvette8n's Avatar
Powered by a spare 12 volt car battery.
Old 06-26-2020, 07:55 PM   #4
deuce_roadster
deuce_roadster's Avatar
What is the use of this thing? If it is for something edible, I sure hope you are using a new unused paint can. There are some pretty deadly chemicals in automotive paint these days that due to their volatility, would vaporize quite easily.
Old 06-26-2020, 08:06 PM   #5
paul2748
paul2748's Avatar
What is a "smoker"
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-26-2020, 10:45 PM   #6
corvette8n
corvette8n's Avatar
For finding evap leaks in modern cars.
Old 06-26-2020, 10:55 PM   #7
Tinker
Tinker's Avatar
Yeah, I always questioned beer can chicken. Not sure I would want to bake a chicken with a aluminum beer can with painted graphics and an inside plastic liner. But I guess it tastes amazing. Not my thing.
One thing I miss being up north is not going to the southside to get some amazing bbq off someones front yard.
Old 06-26-2020, 11:43 PM   #8
Tinker
Tinker's Avatar
Modern cars can be tested with a vacuum gauge.
Old 06-27-2020, 11:27 AM   #9
Jack E/NJ
Jack E/NJ's Avatar
>>>12 volt car battery.>>>
4 ohms should do it --- or maybe over-do it. Use a small alligator clip to test at different points along the nichrome. Jack E/NJ
Old 06-27-2020, 11:44 AM   #10
40 Deluxe
But, while you can see smoke, you can't see vacuum! If you have a leak in the evap system, injecting smoke will pinpoint the leak. Whereas if you merely watch a vacuum gauge to see if it drops you still have no idea where the leak is. Plus, if you're hunting an exhaust leak it's pretty hard to pull a vacuum on the exhaust system! But if you inject smoke into the tailpipe any leaks soon become obvious.
Old 06-28-2020, 11:01 AM   #11
Kurt in NJ
Kurt in NJ's Avatar
Ordinary vacuum gauge is not sensitive enough for evap work, they work in inches of mercury, for evap work you need a gauge that works in inches of water, a gauge is more used to confirm the problem, and the repair, smoke is good for finding the problem
Old 06-28-2020, 08:26 PM   #12
Tinker
Tinker's Avatar
Thanks, interesting idea.
Old 06-29-2020, 07:37 AM   #13
corvette8n
corvette8n's Avatar
Got it working, unwound and cut off some of the Nichome wire and got it down under 3 ohms.
Old 06-29-2020, 07:53 AM   #14
Jack Shaft
Paint can smoker..
