Old 10-26-2019, 10:10 AM   #1
FortyNiner
FortyNiner's Avatar
Default Make it Stop! ('46 Deluxe)
Looking for some help from the brake experts on the Barn (that would be anyone who isn't me).
Here's the deal:
'46 Deluxe Tudor
Bone stock
As part of my resto, I replaced:
Master cylinder (twice - as part of my trouble shooting efforts)
Wheel Cylinders
All lines / hoses
Shoes
Springs
The drums were not changed.
After reassembly, I have adjusted the shoes so they are just off the drums.
The MC was bench bled
The whole system has been bled at least four times
The system doesn not leak anywhere
Here's the issue: I have very poor to no pedal pressure. if I pump the pedal a few times, the brakes will function and stop the car. Needless to say, this doesn't make for a safe ride. Searching the Barn gave me some tips - that I have followed - without real improvement.
My question: What am I missing? What did I do wrong? Should I do the Bendix conversion?
Thanks!
Old 10-26-2019, 10:17 AM   #2
petehoovie
petehoovie's Avatar
Default Re: Make it Stop! ('46 Deluxe)
Are you using DOT 3 or Dot 5 brake fluid?
Old 10-26-2019, 10:30 AM   #3
FortyNiner
FortyNiner's Avatar
Fresh DOT 3 fluid.
Old 10-26-2019, 10:42 AM   #4
19Fordy
19Fordy's Avatar
Remove each drum and rub chalk dust on the complete surface of each brake shoe. Reinstall drums and take car for a drive making repeated stops. Then remove brake shoes and see where the chalk dust has worn off on your brake shoes, showing actual brake shoe contact with drums. Also, I have read on Fordbarn that it's a good idea to "taper" the end of each brake shoe lining so that the shoes make better contact with the drum.
Of course, the best thing to do would be to "arc" the brake shoes to make sure they "fully fit" the drums.
Others, may have better suggestions but, that's a start.
Old 10-26-2019, 10:55 AM   #5
marko39
Could still have air in system. How did you bleed them?
marko39 is offline   Reply With Quote
Old 10-26-2019, 11:01 AM   #6
FortyNiner
FortyNiner's Avatar
The MC was bench bled. The lines and wheels were bled with a helper pumping /holding the pedal as I opened and closed the bleeders that had a clear tube attached. Considerable fluid was pumped through the tube (the MC was not allowed to empty) with no signs of bubbles.
Old 10-26-2019, 11:28 AM   #7
cmbrucew
cmbrucew's Avatar
When you said all lines were replaced did that include a nice loop up and down to clear something?
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 10-26-2019, 11:31 AM   #8
FortyNiner
FortyNiner's Avatar
Bruce
I'm not sure what you mean. The lines run true to the factory placement.
Old 10-26-2019, 11:52 AM   #9
supereal
supereal's Avatar
Old Ford brake systems can be difficult to fully bleed because the master cylinder is below the wheel cylinders. With patience, and a couple of gallons of fluid, it can be done. Before you go further, have the system bled with a power bleeder at a shop who still knows about drum brakes. Our bleeder is a small tank on wheels that we pressurize with compressed air. Start with the wheel farthest from the master, at the right rear, and work your way forward, being sure each bleed screw is closed when done. We place a tube on the bleed screws and the other end in a clear bottle to observe any air bubbles remaining as we bleed.
supereal is offline   Reply With Quote
Old 10-26-2019, 12:03 PM   #10
JSeery
JSeery's Avatar
I agree with the air in the lines. Air is getting trapped somewhere or is getting sucked into the system from somewhere.
Old 10-26-2019, 12:07 PM   #11
FortyNiner
FortyNiner's Avatar
Excellent! Thanks for the guidance.
Old 10-26-2019, 01:56 PM   #12
FortyNiner
FortyNiner's Avatar
Gratuitous beauty shot.
Old 10-26-2019, 02:01 PM   #13
Charlie Stephens
Did you have the shoes arced to the drums and how far out are the drums? Hold off on the Bendix conversion, it is nice but $$$. Your brakes should work when you figure out the problem.
Charlie Stephens
Old 10-26-2019, 02:36 PM   #14
alanwoodieman
did you adjust the brake pedal to mc rod correctly? should have a little rattle and no end play when adjust correctly. pedal should move just a little before slack is gone
Old 10-26-2019, 02:38 PM   #15
petehoovie
petehoovie's Avatar
Old 10-26-2019, 02:40 PM   #16
V8COOPMAN
V8COOPMAN's Avatar
Thanks!
You sure will like the Bendix brakes....you'll never look back. If that's what you decide on, DON'T attempt to save a few bucks by going any of the "cheapie" routes. Go to and order from MT Car Products. There is another "big name" outfit selling similar Lincoln-type Bendix brakes and many folks are having trouble with their brake drums of unknown origin. Go look at genuine MT Car Products pieces in the link below! The best part...these Bendix brakes function really well when used on the FRONT of your Ford in conjunction with the ORIGINAL, stock brakes in the rear since the rears apply such a small percentage of the overall braking effect. DD
http://www.mtcarproducts.com/productsgrid.html
Click Links Below __
T5 W/TORQUE TUBE
Old 10-26-2019, 03:00 PM   #17
FortyNiner
FortyNiner's Avatar
I didn't have the shoes arced or the drums turned or checked. The MC rod was adjusted to minimize play. Once I have a more firm pedal, I'm expecting to encounter the next layer of issues. Will keep these in mind going forward. Appreciate the input.
Old 10-26-2019, 03:33 PM   #18
TJ
TJ's Avatar
Charlie brings up a good point regarding the drums. Even though you did not turn them they may have been turned before and turned too far.
Old 10-26-2019, 11:23 PM   #19
Charlie Stephens
Contact the local Early Ford V8 Club and the local Model A Ford Club and find out who the members use for brakes. There are a lot of Model A Fords that have been converted to the later hydraulics like yours. Finding someone to work on your brakes will be difficult. Most shops no longer have the special adapter to turn the rear hub. Most of the shoe arcing machines have been taken out of service due to OSHA requirements to fit them with special filters to trap dust. Don't take them to a shop that doesn't know how to work on the early Ford brakes, they can do a lot of damage. It will take a little chasing around but I really think it is the solution to your problem. Please keep us posted.
Charlie Stephens
Old 10-27-2019, 06:09 AM   #20
Terry,OH
Terry,OH's Avatar
When you adjust the brake cams do have some drag to each shoe.
