09-04-2017, 06:15 PM | #1 |
LED Turn signals erratic flashing
I have a 12 volt system with an alternator and and FS point less electronic ignition. My LED turn signals cycle on and off on a regular beat when the engine is off. When the engine is on they cycle at an erratic beat. They will signal traffic in either instance but it I do not like the erratic cycle. My system uses a electronic flasher for LED lights I bought from a Model A vendor. It has a three spade plug and lead that goes to ground. Incorporated into a simple lever turn signal unit with an incandescent monitor light on that unit. Power to signal unit is direct to the battery. For diagnosis I hooked a 12 volt incandescent light in place of the of one of LED signal lights. Same results. One friend has suggested that it could be ignition noise?. Could I have a failed flasher unit? Any help appreciated, my friend has heard of others with similar problem.
09-04-2017, 11:18 PM | #2 |
Re: LED Turn signals erratic flashing
If a diode is bad in alternator it would introduce AC current into circuit.
Try disconnecting alt belt and run engine to see if problem is still there. |
09-04-2017, 11:47 PM | #3 |
Benson, Thank you for the reply, before I do as you suggest - if I have a bad diode would't my alternator not work? It charges the battery as usual and the ammeter shows charge on start up and settles back to zero after a bit. This symptom has been with this car for a year and I've had no battery or power issues. The alternator is the wire one style.
09-05-2017, 07:45 AM | #4 |
Not sure what you mean about your lights flashing erratically. I put LED turn signals on my wife's roadster and the lights flash about twice as fast as normal but with a steady on and off cycle, even after adding resistors in the circuit. When following behind her car, the quick flashing LED's really get your attention; more than a normal cycle would. So, I left them alone, feeling it was safer that way from the tailgating idiots. If your's is truly erratic, that's another story and I agree worth looking into and correcting.
Glen
'31 Model A Deluxe Roadster '31 Chrysler Model 70 Sedan '88 Pontiac Fiero GT '36 Auburn Boattail Speedster replica |
09-05-2017, 10:30 AM | #5 |
Had exact same problem with exact set up. Easy experiment, we removed the piazzo buzzer and changed out the fancy electronic flasher to a stock Bussman 550 12 volt one ($3). Now the system works properly with rear LED"S. Not sure which component caused the issue but we tried a new "electronic" flasher again with erratic result. Also, check for good ground from the flasher and the turn signal unit on the column .
09-06-2017, 09:44 PM | #6 |
09-06-2017, 11:05 PM | #7 |
Our thinking is that the electronic flasher may pick up some influence from the FS system, hence the successful change back in our case to a std. flasher.
09-07-2017, 09:52 AM | #8 |
Try a NAPA "el-13, (x) for power, (l) for load, and (p) for pilot lite. There is no Ground terminal.
This flasher will flash even without a load, uses a relay. JB
Connoisseur of Rust |
09-07-2017, 07:31 PM | #9 |
And the winner is Jerry in Shasta for his "fix". The flasher he recommended works and the only real difference is the one that gave me trouble had a grounding wire manufactured into the flasher. The NAPA el-13 has no external ground and also does not have the click/click sound of the other one. I'm 100 % sure that electronic ignition upsets the other grounded version with some type of "noise". Thanks Jerry and I hope this helps others.
09-08-2017, 06:10 PM | #10 |
Your very Welcome
JB
09-08-2017, 06:34 PM | #11 | |
