Old 12-28-2017, 08:06 PM   #1
Tod
Default New B head.
Since my pattern cutting machine just cleared time I decided to start cutting the pattern for the new B head today. Also got my new Mazak horizontal soft wired and powered up to see what things look like.
A lot of glare on the screen due to light from outside but the monitor is clean and clear in real life. This is very good.
Tod
Tod is offline   Reply With Quote
Old 12-29-2017, 11:00 PM   #2
JRN1967
JRN1967's Avatar
Default Re: New B head.
Is that an M Plus control?
JRN1967 is offline   Reply With Quote
Old 12-30-2017, 08:10 AM   #3
Tod
Yes.
Tod
Old 12-30-2017, 09:38 AM   #4
Kraton
Great news. I am looking forward to it.
Kraton is offline   Reply With Quote
Old 12-30-2017, 10:29 AM   #5
Terry, NJ
Terry, NJ's Avatar
Tod, Will it use the B (3 bolt) water pump or the A (4 bolt) configuration ?
Terry
Old 12-30-2017, 12:16 PM   #6
Tod
Terry
3 bolt pump. The chamber will be like a Winfield crow's foot with stock location plug.
Tod
Old 12-31-2017, 01:06 AM   #7
JRN1967
JRN1967's Avatar
We always open up the Z axis cover and set our best level on the guide. If you have two precision levels one on Z and the other on X it helps to get it earth leveled. By the pic, it looks like you were able to get it homed out ok. But I see an E-stop.
I assume its a 40 taper? Did you try a tool change? If its loud don't start running it yet.
Can you post a far away pic of the machine?
Old 12-31-2017, 01:32 PM   #8
hardtimes
hardtimes's Avatar
Tod
Hey Tod,
Sounds like a NICE head offering ! Please post pic of first finished one with top/bottom for us, thanks ! Cannot go wrong with that crowfoot chamber.
Old 01-03-2018, 06:39 PM   #9
Tod
Originally Posted by hardtimes View Post
Hey Tod,
Will do. Today I finished the rough cutting of the pattern and started on the finish pass. Looks good so far.
The Darton sleeves came in for the first two aluminum blocks and they look great as you expect Darton sleeves to look. Checked out dimensionally so now I need to get them installed.
Tod
Old 01-03-2018, 10:27 PM   #10
Smog Tech
Smog Tech's Avatar
I have a Winfield Red Head with the crowfoot chamber on my 1930 Town Sedan. Love that head.
Smog Tech is offline   Reply With Quote
Old 01-04-2018, 10:35 AM   #11
Bob Bidonde
Bob Bidonde's Avatar
What will the compression ratio be?
Bob Bidonde
Old 01-04-2018, 03:53 PM   #12
Tod
In the 6:1 range.
Tod
Old 01-04-2018, 05:07 PM   #13
Tod
Rough cutting the pattern.
And... the sleeves for the first 2 aluminum blocks got here.
Old 01-04-2018, 05:44 PM   #14
Charlie Stephens
Tod,
It would sure be nice if the B head was cast iron and had the letter "C" on it.
Charlie Stephens
Old 01-05-2018, 02:08 PM   #15
hardtimes
hardtimes's Avatar
Hey Tod,
Thanks for the pictures. That is one nice looking head !
And, the sleeves look like jewelry ...for engine lovers !!
Now, after seeing sleeve pictures, I think that images answer a question that I was curious to know answer of...i.e.- how are sleeves 'anchored' to block ? Does that ledge go on top of block, where head actually helps keep it in place
Old 01-05-2018, 02:15 PM   #16
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by Charlie Stephens View Post
Tod,
Charlie Stephens
What?? A wooden head isn't good enough for ya??
Old 01-05-2018, 03:51 PM   #17
Tod
Hey Tod,
The main anchoring is done by metal crush on the OD of the sleeves. There is usually a couple thousandths of crush on the sleeves. The block is heated and it expands so that the sleeves slide in and when the block cools it squeezes the sleeves. The flange on top helps insure that it cannot possibly rise due to the head being torqued down on the sleeves.
Today the finish pass on the B head pattern was completed. It sure looks nice. I made it out of wood because I don't expect sales of this head to be very high. And, I probably will put a "C" on it as the originals have.
Tod
Old 01-06-2018, 01:42 AM   #18
hardtimes
hardtimes's Avatar
Tod
Hey Tod,
Thanks for details of installation ! I like the idea of the head locking the sleeve down. I think that's one modern method used for that purpose.
I happen to have a C head lying nearby in the shed, if you need a picture of exactly where that C is located. If needed, let me know and I'll PM you a picture.
Old 01-06-2018, 02:01 PM   #19
Charlie Stephens
Hey Tod,
Why don't you post the picture here also as well as PM'ing it. There may be a couple of versions of the head as time went on. Any chance you could explain how to attach a picture to a PM? I haven't been able to do it.
Charlie Stephens
Old 01-06-2018, 02:17 PM   #20
Tod
Charlie Stephens
This is what I am familiar with.
Tod
