Old 06-21-2016, 11:11 AM   #1
Mr. Will
Mr. Will's Avatar
Default Just Picked up This 36
Hi guys, Its been a while sense I have posted but I do check in every so often to see what has been going on.
I just picked up this little 36 Cabriolet, all stock. I want to change it over to hydraulic brakes and keep the wide 5 wheels. My question is can I just change out the spindles to the later 37-48 spindles, use the 39-48 backing plates and my stock wide 5 drums?
Any help would be appreciated.
Thanks Dan
Mr. Will is offline   Reply With Quote
Old 06-21-2016, 12:17 PM   #2
Mart
Mart's Avatar
Default Re: Just Picked up This 36
Nice find. You might find that the conversion to hydraulic brakes pushes the wheels out in the fenders a bit. I think (not 100% sure) that you will need 39 hubs/drums in addition to the parts you have listed. The question has to be asked, why change? If the brakes are in good condition they should stop the car ok.
Mart.
Old 06-21-2016, 12:23 PM   #3
40cpe
40cpe's Avatar
I can't help with the brake question, but congratulations!, that is a nice looking car.
40cpe is offline   Reply With Quote
Old 06-21-2016, 12:29 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Thanks Dan
That's a heck of a nice ol' '36!
Using the '37-'48 spindles, you'll need to use '37-'39 front drums to retain the wide-five bolt pattern because of the ONE-YEAR-ONLY '36 drums having a LONGER SNOUT to match the oddball '36-ONLY spindle length....but YES, your combo will work. The long snouts can be seen below. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-21-2016, 12:56 PM   #5
J Witt
J Witt's Avatar
Nice piece of info about the '36 front drums/spindles.
My phaeton will slide the tires with the mechanical brakes and stops the car in traffic easily. Personally wouldn't think of changing to hydraulics. Just my preference.
John
Houston, Tranquility base here. The Eagle has landed.
J Witt is offline   Reply With Quote
Old 06-21-2016, 01:12 PM   #6
V8ER
Install floaters, not hydraulic.
V8ER is online now   Reply With Quote
Old 06-21-2016, 01:51 PM   #7
flatheadfan
flatheadfan's Avatar
Dan-
I just finished changing my '36 cabriolet over to hydraulics. You must use '37-'48 spindles and '37-'39 front drums. For me this was the hard part. Finding usable front drums proved difficult. Many people think '36-'39 are the same. they are NOT. Rear drums can be used as is. For mounting, I used the V8 shop's fixture. I had to do some minor changes to get it to do what I wanted one of which was a remote filler.
Tom
flatheadfan is offline   Reply With Quote
Old 06-21-2016, 02:51 PM   #8
Mr. Will
Mr. Will's Avatar
Great information that is exactly what I needed.
Thanks...
Old 06-21-2016, 02:52 PM   #9
Mr. Will
Mr. Will's Avatar
I'm also looking for a nice set of 39 pedals. If anyone has a set please let me know.
Thanks Dan
Old 06-21-2016, 02:53 PM   #10
Vonn Ditch
You are a very strong man.
Vonn Ditch is offline   Reply With Quote
Old 06-21-2016, 03:14 PM   #11
corvette8n
corvette8n's Avatar
Wow nice score.
Old 06-21-2016, 06:34 PM   #12
alanwoodieman
just put a set of Flathead ted's floaters on a 36 sedan, this is the 3 rd set I have put on. 29 model A, 34 coupe. they work like hydraulics and half , no make that 1/8 the trouble converting of to hydraulics. think about this and then go to flatheadteds website and loo it over
alanwoodieman is offline   Reply With Quote
Old 06-21-2016, 07:52 PM   #13
JM 35 Sedan
JM 35 Sedan's Avatar
Mr Will, did you sell that nice '35 coupe pictured in your Avatar? I remember your posts in the past and all the work you did on that coupe. Was very surprised when you mentioned plans to sell it. What all do you have in the cards for this nice '36 Cabriolet?
John
Old 06-21-2016, 08:00 PM   #14
Lawson Cox
Lawson Cox's Avatar
I went with floaters on my 36 and was very pleased. Nice buy, by the way.
Old 06-21-2016, 11:06 PM   #15
Mr. Will
Mr. Will's Avatar
Yes I did sell that car and am sorry I did. I have been watching for a roadster but they are hard to come by so when this car came up I jumped.
I am basically going to do the same thing to this car that I did to the coupe. I have plans to tow my Kozy-Kamp so keeping the mechanical brakes is out of the question.
Old 06-21-2016, 11:08 PM   #16
Mr. Will
Mr. Will's Avatar
I did find a set of 37-39 wide 5 front drums and backing plates from a friend but still need a set of backing plates for the back.
Old 06-21-2016, 11:33 PM   #17
JM 35 Sedan
Sounds good, but IMHO, if I was planning to put hydraulic brakes on any of my '35's at this stage of the game, I would spend the $$'s and go with the MT Lincoln brakes made here in the USA.
John
Old 06-22-2016, 09:20 AM   #18
TJ
TJ's Avatar
Thanks Dan
Did you get that cabriolet from Memory Lane Motors? It looked good in their photos.
Old 06-22-2016, 11:29 AM   #19
Mr. Will
Mr. Will's Avatar
Yes I bought it from Dale, he is who I bought the 35 Coupe from as well.
Old 06-22-2016, 11:30 AM   #20
Mr. Will
Mr. Will's Avatar
From what I understand the Lincoln backing plates will not work with the wide 5 drums?
