01-13-2015, 01:57 PM | #1 |
'56 victoria ignition key cylinder removal
Can the ignition key cylinder be taken out without a key on a '56 victoria? Or how can I replace the cylinder with a new one if I don't have the original key for my switch? Thanks, Joe
01-13-2015, 04:15 PM | #2 |
Re: '56 victoria ignition key cylinder removal
If the switch is worn enough that you can move it to the ass position with a screw driver, then you can use a paper clip in the little hole and remove it. Not sure how if it needs the key.
01-13-2015, 04:33 PM | #3 |
Or take the whole switch to a locksmith and have it re-keyed.
01-13-2015, 05:32 PM | #4 |
Thought about doing that, but just asking if anyone had any ideas prior to going that route. Thanks, Joe.
01-13-2015, 06:57 PM | #5 | |
Ponymares method works with later 60s and on ignition switches, the 56 is different. If you can't get the key out, it is not a hard job for a locksmith.
Rick West Australia 1958 Ford Mainline Utility, 1955 Ford Tudor Sedan Quote:
01-14-2015, 02:11 AM | #6 |
