02-18-2018, 08:52 PM | #21 |
Re: Maybe the wrong place for this but. . .
Its like soda or pop 8 or 9 should have tipped you off.
Its 1965 1966 Mustang But its all apart do axles fit. You need the CE kit do that first. |
02-18-2018, 09:54 PM | #22 |
Clear as mud, now! This explains everything!! DD
02-18-2018, 10:39 PM | #23 |
this had never been apart. it was missing the drums, but I knew I had some. but the holes to small, or the axles too big. as far as the kit from CE, I know I need to have it here, someone had said they didn't have to move his perch's , so I thought maybe i'll be lucky too.
02-18-2018, 11:16 PM | #24 |
i've been standing outside for an hour, still dont hear you singing, so, i think its a 9"
02-18-2018, 11:20 PM | #25 | |
Not sure I follow you here, but as far as the pumpkin go's, I believe it is an 8" Be nice to see a better picture of the bottom of the pumpkin tho. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN Last edited by Lanny; 02-18-2018 at 11:27 PM. |
02-18-2018, 11:34 PM | #26 |
02-19-2018, 12:10 AM | #27 |
it was more of a hill, but we set up a p.a. it was loud, the cops came and told me to shut up.
02-19-2018, 12:15 AM | #28 |
OK, now it all makes sense. i think.
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
02-19-2018, 12:34 AM | #29 |
Oh, and just to help clear things up, I found a picture of Chuck the Chunk
02-19-2018, 12:41 AM | #30 |
smiles are good for your health
02-19-2018, 01:55 AM | #31 |
Yogis May still have CE kits They didn't stop me if I were to buy.
AS-2016CG
1936-40 Ford Dual Leaf Rear Spring Kit $570 CE They are good kits. I think you have a Mustang 1965 1966 Rear end . I was stationed in Kansas and they called soda - pop Call them and ask. Maybe DD and fly and pick it up for you and do some crop dusting. |
02-19-2018, 03:40 AM | #32 |
yogi's are out of the kit, but they have the springs. I was going to order them and make the rest, when the order taker said he heard CE was about a month off from re-starting under the new owners. he also said he had three orders already and would I like to get on the list. yep. so now we wait. I've got a guy who wants the banjo rear but I said I might need to move it around, so he's waiting to.
02-19-2018, 08:44 AM | #33 |
And the moral of this story?????
NEVER,NEVER buy a rear axle unit thats not complete !!!!!!! I usually call "Curry" and they can walk ya thru the many Ford drum and axle posibilitys... https://www.currieenterprises.com/ |
02-19-2018, 09:36 AM | #34 |
Maybe another moral to this story might be..... just keep strumming on the old banjo, and let chubby chunky chuck have the 8 or 9 inch rear
02-19-2018, 09:42 AM | #35 |
02-19-2018, 10:05 AM | #36 |
Wouldn't it be much simpler to just get the drums that fit your axle? No need for all the drama.
Look in a supplier catalog, such as Bendix, they list all of the specifications for each drum including the center diameter. Just start searching various possibilities for the origin of your axle and see if that is the drum you need. It will also allow you to ID potential axle sources. http://www.bendix-brakes.com/product...rigin=redirect As an example, say you think it is from a 70 Maverick. This is a 10" drum with a 2.437 center hole. A 65 Mustang would be the same. A 70 Custom has a center hole of 2.778, but is an 11" drum. You would need to check all of the specs to see if any drum fits your axle. Last edited by JSeery; 02-19-2018 at 10:27 AM. |
02-19-2018, 10:07 AM | #37 |
Through all my years messin' with this old junk I've heard 'em called center sections, third members and also CHUNKS (usually by the guys missing a tooth or two), but never heard any reference to a CHUCK. DD
02-19-2018, 10:21 AM | #38 |
Thanks Guys for the tip. I have been calling it a chuck.
No wonder I can't sell it on Ebay Now I can get $150 more. |
02-19-2018, 10:28 AM | #39 |
02-19-2018, 10:48 AM | #40 |
Makes sense to me.
