07-30-2019, 02:27 PM | #1 |
Flathead fan pulleys
I’m preparing to put a ‘53 Flathead into a ‘31 truck project of mine and noticed that the fan pulley spacer between the pulley and the fan mount seems long (4 inches)... anyone have any info on a possible alternative that would be shorter?
07-30-2019, 02:34 PM | #2 |
Re: Flathead fan pulleys
Will this help?
https://www.bobdrake.com/FordItem.aspx?Item=21A-8600-K |
07-30-2019, 02:40 PM | #3 |
Thank you! A little pricey yes, but I believe that answered my question that a shorter option is available 👍
07-30-2019, 03:24 PM | #4 |
I can honestly tell you from experience that you couldn't make one for that money. 6061 aluminum is expensive and so are the bearings and the machining required. I know because I made this one in 1999 before Drake started making his a few years ago. DRAKE has raised price $20 since last year so the price will never be going down. The one I made is on an 8BA with other modifications. Call DRAKE and ask for the critical measurements you need to know about. Good luck on your project. Last edited by 19Fordy; 07-30-2019 at 03:29 PM. |
