Old 10-02-2021, 04:32 PM   #1
lotsagas4u
Default Points don't fit
Bought a set of points from one the A parts dealers. The points don't fit so well. There is part of the front hanging off the point face. This is my first time of installing points in a model A. Is this common? Who has the best quality, original style points?
Thanks
lotsagas4u is offline   Reply With Quote
Old 10-02-2021, 04:47 PM   #2
Ruth
Default Re: Points don't fit
I like Bratton's. I also use their machined stationary point block. It is made to align the pointshttps://www.brattons.com/MACHINED-DI...uctinfo/17351/
Ruth
Old 10-02-2021, 05:00 PM   #3
nkaminar
nkaminar's Avatar
A photo would help.
Old 10-02-2021, 05:22 PM   #4
Patrick L.
Patrick L.'s Avatar
Yep, seems to be a problem sometimes.
I've had to do some drilling/filing to get them where they need to be.
Old 10-02-2021, 07:47 PM   #5
Greg Jones
Greg Jones's Avatar
Yeah that is because they don't make the points correctly nowadays and apparently can't be bothered to correct it. The workaround is per above, the vendors sell a specially machined point block that better (but not perfectly) aligns the points. Welcome to the world of reproduction parts. This is an example of what makes me nuts about some reproduction parts-like, why couldn't they just make it correctly?
Greg Jones is offline   Reply With Quote
Old 10-02-2021, 10:20 PM   #6
1crosscut
1crosscut's Avatar
The fixed side of the point block will need to be moved some to align the points. Put a mark on the lower plate at each mounting screw to indicate the direction it needs to move. Remove the points block and elongate the two holes in the direction of the marks using a small rat tail file. Do a little at a time and check the fit until you get it to line up. Doesn't take long and works well.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 10-03-2021, 11:01 AM   #7
katy
katy's Avatar
The lower plate that was in the distributor of my A had a fixed point block and the new replacement points didn't line up. I had to source a new lower plate and point block and then file the point block mounting holes to get the points to line up.
Old 10-03-2021, 01:06 PM   #8
J Franklin
J Franklin's Avatar
I like to buy nos or nors points because they usually fit. Use the good points until they are worn completely done and you will be surprised how many years they will give good service. Some people just replace points for no real good reason and then find these other problems!
Old 10-03-2021, 01:24 PM   #9
JD 1931
JD 1931's Avatar
NAPA has good points and condensers
JD 1931 is offline   Reply With Quote
Old 10-03-2021, 02:01 PM   #10
Gene F
Gene F's Avatar
Just look at Katy's photo. That's not even close to a good part.
Old 10-03-2021, 02:43 PM   #11
Ruth
I can't even imagine where Katy buys parts...
All parts from Bratton's. All repro and fits fine.
Ruth
Old 10-04-2021, 09:36 AM   #12
katy
katy's Avatar
Brattons
Old 10-04-2021, 10:22 AM   #13
Ruth
Originally Posted by katy View Post
Brattons
Well as you can see from my picture, with Bratton's stationary block cures the problem with no modification to the upper plate.
Ruth
Old 10-04-2021, 12:45 PM   #14
KGBnut
KGBnut's Avatar
I've never seen one like that. Is the plate cast with the points block in place?
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 10-04-2021, 01:15 PM   #15
Bob C
He's got the early plate with the cast in point contact block.
Old 10-04-2021, 01:24 PM   #16
KGBnut
KGBnut's Avatar
See that...you learn something new every day.
Thanks,
Ken
Old 10-04-2021, 03:48 PM   #17
Ruth
Notice how the screw on Katy's plate is outboard compared to the Bratton's, locating the stationary point inward causing the miss alignment. it doesn't appear to me that bratton's points were designed to work on that plate.
Ruth
Old 10-04-2021, 04:25 PM   #18
J Franklin
J Franklin's Avatar
Did an early plate distributor get different points?
Old 10-04-2021, 07:02 PM   #19
chrs1961815
chrs1961815's Avatar
Not that I can tell.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
