04-30-2018, 02:01 PM | #1 |
1929 CCPU Top Assembly
I am building a 1929 CCPU and have completed the pieces for the wood top. I am considering putting the wood pieces together on the truck with some glue which would allow me to deal with the top as an assembly instead of individual pieces.
Painting the top would be a lot easier as an assembly but disassembly would obviously be more difficult. Is there a good reason why the wooden top pieces should not be glued together? |
05-01-2018, 08:49 AM | #2 | |
Re: 1929 CCPU Top Assembly
The wood top was painted with the cab in body color. Ford didn't glue the wood together. I don't see any reason to use glue.
[email protected] - email contact https://aafords.com Ford Model AA Truck Club @ aafords.com |
05-01-2018, 09:05 AM | #3 |
Rex,
I don't think you should glue the wood pieces together. The cab will "flex" slightly. Maybe if the wood was glued together it would hold up to flexing, but who knows. I don't see what would be gained by gluing the wood together as you would still need to fasten (screws and bolts) the wood pieces together and to the cab. This is the reason Ford used rivets to fasten the frame together instead of welding the frame pieces together - to allow some flexing. Rusty Nelson |
05-01-2018, 03:15 PM | #4 |
Thank you to Rusty and Neil for the comments.
I will put the top together as it was originally designed by Ford. No glue..... |
05-05-2018, 12:00 PM | #5 |
Rex I put my 29 together about aover a year ago and took alot of pictures as I did if you have questions just hit me up.
05-05-2018, 04:05 PM | #6 |
Nothing beats experience. Rex |
05-13-2021, 10:15 AM | #7 | |
Bill, could I get you to send those pictures to me? I just got a 29 truck that is missing all the top wood. Thanks in advance I know this thread is 3 years old, but I hope Bill sees this. Thanks Last edited by Packrat; 05-13-2021 at 10:22 AM. Reason: to clarify |
05-13-2021, 08:34 PM | #8 | |
Sorry, Bill hasn’t been on the site since 09/2020. Sent from my iPhone using Tapatalk |
05-18-2021, 08:38 AM | #9 |
Thanks, should have checked that.
