09-23-2010, 07:44 PM | #1 |
Fule Line Question
My truck has a copper fuel line from the glass bulb to the carburetor. I understand that you are not supposed to use copper for this application. Replacement fuels lines from the parts places all enter the carburetor on the side, but mine enters on the front. In other words, the fuel line makes a 180 degree bend. I believe it is an original style carburetor as it looks like all the others i see in pictures except the inlet is in front.
Does anyone else have this style carb? Does anyone else have a copper fuel line? Can i just use steel brake line with copper ferrules and nuts? As always, thanks a bunch! Bob |
09-23-2010, 07:50 PM | #2 |
Re: Fule Line Question
I know fuel is spelled wrong. I don't type so well!
09-23-2010, 07:54 PM | #3 |
Can you post a photo of the carburetor? I have never seen one like you are describing. Is there a plug in the side? If so, it sounds like maybe someone put a plug in the fuel inlet and is using the gas filter mounting location as the fuel inlet.
09-23-2010, 08:10 PM | #4 |
Re: Fuel Line Question
Here are some photo's. There is no plug in the side.
09-23-2010, 08:18 PM | #5 |
You have a Model B Carburetor.
09-23-2010, 08:29 PM | #6 |
09-23-2010, 08:37 PM | #7 |
Just cut a 1 to 1 1/2" section out of the straight section of the copper line and bridge with a piece of fuel injection hose,that will take care of all the vibrations. OMO . Ive run copper line from carb to tank for 20 yrs neverhad any trouble.ken ct.
09-24-2010, 11:05 AM | #8 |
As Ken says, put in a flex section, very important if you are using Float-O-Motor's
09-24-2010, 11:32 AM | #9 |
The other thing some people do when running a "B" carb is to put the side bowl from a late '31 "A" carb on the "B" carb which changes the inlet direction 90 degrees so you can use a regular "A" gas line.
Larry Seemann |
09-24-2010, 11:37 AM | #10 | |
I'd be interested in your thinking regarding Float-O-Motors. Do they just let the motor move around enough more to cause a problem? Have you actually seen the problem, or is this a theoretical concern? What you think about just using an all-rubber fuel line? I'm sort of interested in the FOM issue. On the one hand, all of the arguments I've heard against them make a lot of sense, but, on the other hand, I know a lot of folks who have used them for many thousands of miles with nary a problem. THanks! Bob, You might be able to rig an adapter elbow that does the job of the sidemount filter bowl using brass fittings. I've had good luck just taking a carb and essential fittings into an auto parts store and pawing through their big cabinet with fittings. Steve Last edited by steve s; 09-24-2010 at 12:07 PM. |
09-24-2010, 12:05 PM | #11 |
woa woa woa i am trying to grasp this using a rubber hose for fuel line flex with floater mounts. has there been breakages of the steel lines because of the mounts? i never thought about this and know of lots of cars running the floaters with all steel lines. enlighten me some please.
09-24-2010, 01:43 PM | #12 |
The Float-A-Motor set ups could "over flex" even the stock steel fuel line. All the later Ford products with rubber isolated mounting used a flex line from the firewall to the pump. Copper tubing fatiges at a higher rate than steel but even a steel line could fatigue crack with a Float-A-Motor kit installed.
I've had more problems (leaks) with the cheep crap modern rubber fuel line than any copper or steel line but I guess that's a sign of the times. Not good to have fuel leaking on a hot exhaust manifold for sure. |
09-24-2010, 03:22 PM | #13 | |
I too am struck by the absence of first- or even second-hand experience with FOMs actually causing a problem. |
09-24-2010, 04:58 PM | #14 | |
i think i would feel more comfortable with a full steel line even if i had to bend one up for a certain application with a tubing bender. i have seen to many rubber hose fires such as the more modern carburated fords with the small rubber hose in front of the fuel filter next to the distributor. what would scare me on the A is not only the manifold but also the bare plug connectors (wires). |
09-24-2010, 09:41 PM | #15 |
Steve, what kind of carb is that?
09-25-2010, 04:04 PM | #16 |
Bruce,
Behold, the New Zenith, sometimes disparaged as The Forklift Carb. Search under its model number on invoice might turn up prior threads. Tends to excite passions. Steve |
