10-13-2014, 09:38 PM | #1 |
The saga continues
Got the engine and trans in the frame today ran into a problem with the U[joint cant get it on the spline shaft of the output shaft from the trans I know there is a bolt and washer that needs to go into the output shaft to hold the U-joint, but I cant get the U-joint on. There seems to be a small ridge running on the bottom of each of the spline shaft running the length of the shaft that keep the U-joint from going on, any thoughts?
10-13-2014, 09:53 PM | #2 |
Re: The saga continues
Is this a new u joint? Or the one you took off durring your work?
10-13-2014, 10:05 PM | #3 |
Are you sure you're trying to slide the proper end of the u-joint onto the output shaft? The ends are different sizes/splined differently.
Aaron in Tacoma (although still a Montana hillbilly at heart ) |
10-13-2014, 10:51 PM | #4 |
It is a new to be me but a used Ujoint. I put it on per the picture in Les Addrews book. Also I put it the same way as the ujoint that was on the old engine and trans that I took out.
10-13-2014, 11:06 PM | #5 |
Do you still have your old u joint? Try putting it back as a test of the spline of the trans.
10-13-2014, 11:11 PM | #6 |
