02-03-2013, 07:41 PM | #1 |
How to move front seat back in 29 coupe?
Hi can someone tell me the best way to get leg room by moveing seat back? Thanks RICH
02-03-2013, 07:58 PM | #2 |
Re: How to move front seat back in 29 coupe?
About the most you can do is remove the square wood spacer in fronbt of the package shelf if it's still there. I removed mine , it moves the backrest back about 1-1/2". I'm 6-2 and have enough room.
02-03-2013, 08:24 PM | #3 |
What Barry said can easily be done. What Barry described gives you a little more back room, but not extra leg room as the bottom of the backrest stays the same even after the top wood is moved back. There is a fairly easy way to get a little more leg room. In the service bulletins on page 257 there is a section that shows a longer bracket that attaches to the rear part of the seat riser. I don't know if you have the service bulletins or not. If you don't, I could send you a picture of the page attached to an email. Since I am 6' 4", I did one more thing to achieve more legroom. I had Snyder's make a custom backrest spring that is 2" thinner then the original spring. The thinner spring just barely covers the rear part of the cushion with little to spare, but it gives me another 2" of room. Snyder's charges $25 more than a standard spring to make a custom spring. It should be more comfortable to drive in my 28 special coupe. I am just about finished with the restoration, so I will find out in the spring when the snow melts.
Rusty Nelson |
02-03-2013, 09:31 PM | #4 |
Like this! Bill W.
02-03-2013, 11:28 PM | #5 | |
Fred Kroon 1929 Std Coupe 1929 Huckster |
02-04-2013, 12:06 AM | #6 |
02-04-2013, 08:17 AM | #7 | |
02-04-2013, 08:55 AM | #8 | |
https://www.youtube.com/watch?v=in1eK3x1PBI ( I have the same issue : 6' 2", size 13-A feets. Have to go in head-first, feet toe-first. Getting-out: Butt-first, left-foot out (heel-first) weight on running-board, then hunch-forward, and ease-out backwards, reversing the in-bound trip. The only way to get more foot-clearance between the A-pillar and the seat riser would be to trim the back ends of the riser, and scoot the whole thing back an inch or two, and I'm not sure if that's really practical. Maybe this is why Fats drove a Lincoln K touring car...) |
02-04-2013, 12:44 PM | #9 | |
02-04-2013, 01:48 PM | #10 |
Did someone say Model A's are tight? |
02-04-2013, 04:04 PM | #11 |
02-04-2013, 04:17 PM | #12 |
Yes, that's Robert, who only lived to be 22 years old. 1918-1940
10-03-2017, 04:14 PM | #13 |
Could you send me this info too please?
