07-21-2018, 11:24 PM | #1 |
40 ford column shift linkage parts
Who sells small items such as original felt washers and etc that go to the steering column shift linkage for the 3 on the tree.
07-21-2018, 11:30 PM | #2 |
Re: 40 ford column shift linkage parts
Bob Drake has shift kit that includes rubber for column shift handle.
https://www.bobdrake.com/FordItem.as...=01A-SHIFT-KIT C and G has kit, but comes without punch to assemble grommet. If you have a lathe you can easily make one. https://cgfordparts.com/ufolder/cgca...&searchnumber= Dennis Carpenter probably has them also. Last edited by 19Fordy; 07-21-2018 at 11:35 PM. |
07-23-2018, 07:06 PM | #3 |
The parts I am needing on the attached diagram are:7314,7323,7337,351560-s,34746-s,351341-s.
07-24-2018, 06:27 AM | #4 |
C&G Ford Parts has part # 01A-7323. I didn't check for the rest of the parts you listed, but give them a call. Sometimes a call is better than the internet.
https://www.jalopyjournal.com/forum/...gs-etc.956972/ |
07-24-2018, 07:00 AM | #5 |
