03-03-2019, 02:58 PM | #1 |
Boling Brothers Brake Conversion
Installed several set of these self-energizing brakes and decided to take some pictures of these installed on a 40 coupe. As you know if you have read/done one of these conversions you need to remove "some material from the spindle" these pictures should tell the story
03-03-2019, 03:16 PM | #2 |
Re: Boling Brothers Brake Conversion
Hi, Do you have any follow up pictures of the backing plates mounted to the spindles. Also, did you happen to notice that the wheel cylinders are not centered on the brake shoes. If so what did you do, if anything, to correct the issue?
03-03-2019, 04:07 PM | #3 |
BoxCarTom: Here's a good article on how Bendix brakes work and why they are better than Lockheed.
https://www.hotrod.com/articles/0911...system-basics/ On my Boling Bros (MT Products kit) I didn't notice if the wheel cylinders were centered or not but, because of the way the Bendix brakes literally "float" inside the brake drum to create the self-energizing action,I don't think it's critical like as with Lockheed brakes where the shoes move only in an outward direction as pedal pressure increases. The Bendix brakes actually move or "float" and the wheel cylinder pistons compensate for the extra movement, I believe. I am sure boling bros would have engineered their set up properly. I sent you a PM about the brake install. |
03-03-2019, 04:09 PM | #4 |
Great pictures. I've done dozens of this conversion for customers chassis and my own cars. I find if you use the right MC and they're adjusted properly they work excellent.
03-03-2019, 04:28 PM | #5 | |
The original Lincoln brakes were 1 3/4" wide. The MT/Boling Bros brakes are available in 1 3/4" width (for original Lincoln drums) or 2" width (only for BB repro or Buick) drums. As I recall, the wheel cylinders are centered on the shoes only with the 1 3/4" shoes (since the repro backing plates are essentially the same as the original Lincolns in this respect). For the 2" shoes, the questions seem to be:1) is the cylinder/shoe offset OK and 2) can/should the wheel cyl be shimmed 1/8" to eliminate the offset?
Those who do not move do not die, but are they not already dead? |
03-03-2019, 05:36 PM | #6 |
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand https://www.fordbarn.com/forum/album.php?albumid=580 |
03-03-2019, 05:51 PM | #7 |
meric42 I was simply referring to a MC designed for drum/drum brakes. There is nothing wrong with your setup. On my new installs I use a dual master cylinder designed for drum/drum with residual valves built in.
03-03-2019, 06:21 PM | #8 |
Cheers, thanks for the clarification.
03-03-2019, 09:26 PM | #9 |
I used F-100 brakes on an early spindle and I also had to grind the spindle down
03-04-2019, 09:29 AM | #10 |
F1 brakes on early spindles only require a little grinding where there is interference with the drake hose connection. I have also done a few of these and they are a lot easier to do, but you have to change bearings, use the F1 hub/drum. I used to be able to get these from junkyards/hot rodders for next to nothing, but they are drying up and by the time you buy all you need new it is easier and cheaper to do the conversion than the change over to F1
03-04-2019, 09:32 AM | #11 |
krylon32 ,what dual MC did you use and how do you access the top fill? 67-68 mustange has been suggested
03-04-2019, 10:37 AM | #12 |
Here's another view of the front spindle modification on a 40 Ford for the MT Brakes.
I made a grinding template. If anyone needs one just send PM. |
03-04-2019, 10:39 AM | #13 |
Do you have a part number for this master cylinder? Does it require a 3 bolt to 2 bolt mount adapter?
03-04-2019, 01:24 PM | #14 |
dual master cylinder conversion will require a three to two adapter. attached are pictures of the backing plate/wheel cylinders on the BB conversion. A comment was made about the wheel cylinder being not centered, but upon closer inspection they are centered on the king pin, which must make them work better
03-04-2019, 04:56 PM | #15 |
The master cylinder numbers are Cardone 10-1292 and 10-1329. They have 2 bolt flanges. The only difference is they exit on different sides. I'm not in the shop so can't tell you which sides they exit on but I've used both successfully on my drum/drum chassis. They have residual valves built in and I've never put anything else in the lines except a brake switch port. I always plumb in both directions with 3/16th line. I've done not only several of my own but dozens of customer chassis this way with no problems.
03-04-2019, 05:13 PM | #16 |
It has been mentioned several times that if the stroke on the brake pedal isn't long enough, the dual master cylinder can't do its job if one circuit fails. Is the stroke on the under-floor mounted brake pedal adequate to stop the car if a failure occurs using one of the dual chamber cylinders?
03-04-2019, 05:17 PM | #17 |
IF I looked them up correctly, the Cardone 10-1292 connections are on the left and the 10-1329 has them on the right.
03-04-2019, 05:44 PM | #18 |
That looks correct. They do have a Chevy bolt pattern flange that requires a little massaging for most aftermarket MC brackets as they are designed for Ford MC's. I use P&J under floor MC mounts on all of my chassis and with the massage they bolt on and work with a full stroke to work properly.
03-04-2019, 05:48 PM | #19 |
Regarding dual M/C''s and the stroke... It wouldn't hurt to read rumbleseats experience and comments. If you are putting any 'faith' in that dual M/C, I'd certainly suggest trying his experiment of opening the bleeder at one end, then go out for a ride (in a safe area).
JMHO |
03-04-2019, 06:27 PM | #20 |
Dual M/C doesnt necessarily mean that in some cases. We had a factory ford from the 90s Dual circuit Master on our 49 coupe . 7 hrs from home the brakes went away for the most part as we had a small split in the middle of a rear line. Opened the M/C ,lo and behold the rear reservoir was empty and the front had very little. Don’t know why ,but they are connected somehow.
Some awesome Chevy guys opened their shop and put it on the lift and took charge of the repairs. |
