Old 09-03-2019, 08:06 AM   #1
bullrunmotor
Default PCV Valve for 292 and source for rubber valley/valve cover gaskets
Can anyone suggest what PCV valve& grommet set up fits in place of the draft tube in the oil valley plate. I've seen pictures on the internet-maybe a kit is available. Also-does anyone know a supplier that still supplies rubber-not cork-valve cover and oil valley cover plate gaskets. Thanks a lot.
bullrunmotor is offline   Reply With Quote
Old 09-03-2019, 09:34 AM   #2
Ole Don
Ole Don's Avatar
Default Re: PCV Valve for 292 and source for rubber valley/valve cover gaskets
Grommet and PCV for a Mustang 302. Glue the grommet in, it may not fit perfectly.
Ole Don is offline   Reply With Quote
Old 09-03-2019, 09:23 PM   #3
paul2748
paul2748's Avatar
Have you checked with a local parts store on the rubber gaskets? Try a listing for a 60-64 Ford F150, 292 engine.
Also try John Mummert
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-13-2019, 10:23 PM   #4
My Old Blue
I just went down this road. O'Reillys has the Dorman grommet with the notch to fit the lip in the hole, sorry I do not have the number but I held it in my hand as I needed a thinner notch. PCV I used was Microgard PCV178, it specs out to be the closest match I could find. Both for about $7
My Old Blue is offline   Reply With Quote
Thread Tools
Display Modes
