Old 09-01-2019, 12:54 PM   #1
Beater
Beater's Avatar
Default A head on B engine
what is involved? drill some steam holes? im thinking about using a higher comp A alum head on the B motor
Beater is offline   Reply With Quote
Old 09-01-2019, 02:46 PM   #2
Newc
Newc's Avatar
Default Re: A head on B engine
Hi; My '32 B came with a Model A head and pump, ran fine. In fact it was a Model A "police" Ford high comp head..... a 'B' head. Check the gaskets for any changes. Newc
Old 09-01-2019, 04:07 PM   #3
Beater
Beater's Avatar
well this B has the C head on it, which is high comp I guess. just thinking about going A head so a waterpump is more avalable
Old 09-01-2019, 04:41 PM   #4
Bob C
The stock B head with the C on it is 4.6:1 and the stock A head is 4.22:1.
Bob
Old 09-01-2019, 05:15 PM   #5
Beater
Beater's Avatar
yes I did know that. what I want to know is what has to be don't to use an A head on B block. thinking about using an aftermarket alum head for an A
Old 09-01-2019, 10:35 PM   #6
Newc
Newc's Avatar
Have you ever heard of the S.S.O.S Society? Dedicated to Ford fours. Secret
Society of Speed google it- has been around 25 yrs, based in Ohio. Newc
Old 09-02-2019, 09:03 AM   #7
Kurt in NJ
Kurt in NJ's Avatar
Between #2,3 there's 2 small holes, depending on the head, and gasket used those 2 holes may need to be plugged
Kurt in NJ is online now   Reply With Quote
Old 09-02-2019, 10:51 AM   #8
Beater
Beater's Avatar
or drill out the steam holes to match in the head?
Old 09-02-2019, 01:35 PM   #9
barnstuf
Many years ago I ran a Model A cylinder head on a Model B engine in my 1929 Station Wagon with oversize tires for hard driving on sandy beaches. At the time my nephew was a hot rodder and he threaded bolts into the two steam holes that are in the block, then cut and filed them flat. Used the regular Model A cylinder head gasket, drove many miles over about 12 years, never had a problem.
barnstuf is offline   Reply With Quote
Old 09-02-2019, 01:46 PM   #10
KGS
KGS's Avatar
I'm not a Ford Four Banger guy so the
steam hole doesn't compute with me. Can
any of you guys fill us in? Thanks
KGS is offline   Reply With Quote
Old 09-02-2019, 04:56 PM   #11
Beater
Beater's Avatar
from what ive learned there are two extra " steam holes" in the B block between 2 and 3 cylinder. A doesn't have this added cooling I guess.
Old 09-03-2019, 09:13 AM   #12
1931 flamingo
1931 flamingo's Avatar
Ck out Vince Falter's site or try the A forum OR a search. Steam hole filling has been covered before.
Paul in CT
Old 09-03-2019, 09:51 PM   #13
cas3
vince falters site is wonderful. i believe its "the old ford garage"
cas3 is online now   Reply With Quote
Old 09-04-2019, 05:57 AM   #14
KGS
KGS's Avatar
Thanks. Will check it out.
Old 09-04-2019, 09:36 PM   #15
Tinker
Tinker's Avatar
https://www.jalopyjournal.com/forum/...-links.161498/
There is a monthly "banger" thread. Not sure it's still active.
If not, the model A forum here is good. They know touring As and B motors.
Thread Tools
Display Modes
