Old 09-14-2019, 09:07 PM   #1
My Old Blue
Default Help identifying this dipstick tube
Dipstick tube on my 312 Country Sedan was never bolted to the head. I always thought it was just never attached. I soon discovered there are not enough bends in it. Clearly did not belong to this motor. Can anyone lend some insight where it came from? It does have a under layer of red-orange paint.
My Old Blue is offline   Reply With Quote
Old 09-15-2019, 06:25 AM   #2
ponymare
Default Re: Help identifying this dipstick tube
May have been on the smaller 6, like the 144- 170 or 200.
ponymare is offline   Reply With Quote
Old 09-15-2019, 07:47 AM   #3
TedEaton
TedEaton's Avatar
That tube looks correct for a front sump Y. Without knowing more about it, there's a good chance it was installed upside down in the block thus making the tab on the tube not aligning with the bolt hole in the head. Ted Eaton.
TedEaton is offline   Reply With Quote
Old 09-16-2019, 11:05 PM   #4
Daves55Sedan
Daves55Sedan's Avatar
If you turned it right side up, it looks like it would be for a full-size car Y-block (except the mounting bracket would then be facing the wrong way). Factory blooper maybe???
Old 09-17-2019, 05:56 AM   #5
darrell
i done some measuring on my dipsticks. car is 16 in.i have 2 truck types 15 and 19.that will tell what you have.
darrell is offline   Reply With Quote
Old 09-18-2019, 09:50 PM   #6
My Old Blue
Good info, I'll go measure. I tried flipping it and just won't mount up.
Old 09-18-2019, 10:14 PM   #7
My Old Blue
Thanks Ted. I was able to find information this is being for front sump oil pans (54-62 car):http://www.ford-y-block.com/accessories.htm I'm doing something wrong here in how I'm seeing the fit...I'm gonna go look again at my motor and try to understand why. side note: I found some pictures on yblock tubes and compared to mine..it does appear that it was installed upside down. Thank you Ted
