Old 08-31-2019, 11:29 AM   #1
bo8109b
bo8109b's Avatar
Default 1940 Antenna
Does the through the roof antenna have any provision for keeping it ungrounded as it passes through the windshield frame? A test light shows mine to be grounded. Radio still plays. Carl
bo8109b is offline   Reply With Quote
Old 08-31-2019, 12:35 PM   #2
Kube
Kube's Avatar
Default Re: 1940 Antenna
There is a rubber grommet that disallows any contact between the metal body and the antenna.
"Imagination is a crutch used by those who lack knowledge and intelligence ."
B
. Franklin
Old 08-31-2019, 12:57 PM   #3
bo8109b
bo8109b's Avatar
Can understand a rubber grommet being at the roof sheet metal, but what about where it attaches to the windshield frame with a tightening nut? Carl
Old 08-31-2019, 02:10 PM   #4
Kube
Kube's Avatar
There are a number of plastic "washers" as well as a grommet in that area.
Do you have a complete and authentic antenna?
B
. Franklin
Old 08-31-2019, 02:41 PM   #5
philipswanson
Can someone furnish a picture of how the antenna passes through the garnish rail area? I am stuck on the same thing. I understand how it goes through the roof but confused of where and how it passes through the garnish rail on the inside.
philipswanson is offline   Reply With Quote
Old 08-31-2019, 02:59 PM   #6
4dFord/SC
4dFord/SC's Avatar
Here's what it looks like in a sedan with the mirror removed.
4dFord/SC is offline   Reply With Quote
Old 08-31-2019, 03:10 PM   #7
bo8109b
bo8109b's Avatar
Regret that I didn't take a hard look at the antenna installation when I changed out the headliner. Outwardly appears as an original. With the mirror removed, there appears a 1/2" threaded tube through the wind shield frame held tight by a nut type fitting. Garnish molding starts and stops either side of the nut.
Old 08-31-2019, 07:52 PM   #8
philipswanson
Much different than the wagon though which is what I have.
